Introduction: Popsicle Stick Pirates Chest
Materials:
Popsicle sticks
Hot glue gun
Razor blade and/or scissors
Popsicle sticks
Hot glue gun
Step 1: Assembly
Lay out ten Popsicle sticks then glue one Popsicle stick on each end.
Step 2: Cut
Mark out the center line then cut with razor blade or scissors.
Step 3: Glue and Cut
Lay out ten Popsicle sticks then glue one Popsicle sticks on each end count five Popsicle sticks over then cut. Cut one of these in half and save the other one for later.
Step 4: More Assembly
Glue small side onto big side(see pic)
Step 5: Bottom
Lay the bottom of the chest in between the two assembled pieces, cut to size then remove the little stubs from the end. Once you have finished glue the end back on
Step 6:
Glue on the bottom then the other two sides, then add a rim of Popsicle sticks around the outside.
Step 7: Top
Glue Popsicle sticks in an arch, then add sides
Step 8: Slice
Use a razor blade to separate one side
