Popsicle Stick Swiss Army Knife Prop
Intro: Popsicle Stick Swiss Army Knife Prop
Swiss Army Knife made out of popsicle sticks!
This is a Swiss Army Knife prop that YOU can make using only a couple of popsicle sticks (tounge depressor type).
NOTE: I do not know how to make the blades stop when fully extended. You can turn them until they hit the other side of the stopper. I did not have a Swiss Army Knife available while making this Instructable.
Please post a solution if you can.
You will need:
- 6 popsicle sticks (wide type)
- Superglue
- Drill
- Jigsaw (optional)
- 1/2cm drill bit
- Sandpaper 150 grit and 280 grit
- Pen or marker
This is not a Step-by-step Instructable, so I'm hoping you understand the process from the image notes.
Don't forget to Subscribe and Comment!
You will need:
- Superglue
- Drill
- Jigsaw (optional)
- 1/2cm drill bit
- Pen or marker
48 Comments
TheGeek1984 12 years ago
- Just like the picture, there is a notch on the same side as side C. Sides A and C are roughly the same length, and B actually came out pretty even too.
- I found that it was easier to leave side A rather long, then drill the hole out, and then shorten it to match C.
- The dotted line is just where I tapered the blade, and I colored in the notch for the thumb to pull out the blade. The other notch...I'm not really sure why that's there, maybe aesthetics? I was going off of my little Swiss Army blade.
Again, this is just a rough work up of what I drew last night. I just wanted to make sure that it was possible. Good luck on version 2!colorex 12 years ago
Thanu03 8 years ago
I apologize for the crudeness and poor handwriting...
gUmMy_BeAr 12 years ago
mrsmerwin 7 years ago
I have to try this soon.
Master Wasi 9 years ago
Wow! really cool.:)
ansh90 10 years ago
you know you can break an actual knife and drill a hole and replace the traditional wood right?
but be careful when breaking the knife
use the small ones on not the bud bread knife or something like that
Mahmoud Alaa 12 years ago
Snow man 12 years ago
P.S. how the blades come out of the knife?
Robot Lover 12 years ago
nattyclem 12 years ago
well done and I really hope you win a prize. with you all the way.
