Introduction: Popsicle Stick Switchblade
cool switchblades you can make with just 3 popsicle sticks and 2 rubber bands.
What you need:
3 Popsicle Sticks
2 Rubber bands
Scissors
Step 1: Making the Blade
Cut about an inch off the end of one stick. Making a sharp point is optional.
Step 2: Making the Switch
Next, you will want to cut a 1.25" piece off the second stick. And then cutting another smaller piece off the longer end about a 1/4 will do.
Step 3: Assembly
The image shows how the knife will be laid out.
Step 4: Attach the Blade
Wrap a rubber band around the blade and handle. Not too tight, the blade must be able to rotate 180 degrees.
Step 5: Assembling the Switch
Place the small 1/4" piece on the handle then put the 1.25" piece on top. And wrap with the rubber band.
Step 6: Operating the Knife
Rotate the blade, squeeze the switch open and clasp the blade.
