Introduction: Fire Pot (not a Kashmiri Kangri)
This is an experimental project. A Kashmiri Kanger (Kangri) is a traditional portable firepot used in Kashmir (india) to keep warm during harsh winters. It consists of an earthenware pot filled with hot embers, encased in a woven wicker frame for insulation and easy handling. People tuck it inside a loose woolen cloak (Pheran) to stay warm.
So i thought to a make similar one using an clay plant pot and jute ropes. all the materials are sourced from my house in a limited time since i thought to enter this for stay warm contest
To make this project, I used:
clay pot
jute ropes
metal string
DC motor fan
tapes
toggle switch
potentiometer
wires
Battery
Soldering iron
flux
soldering led
other essential tools
Step 1: Setting Up the Pot
The original kanger is made using earthenware pot and woven wicker frame insulated using willow tree materials. here instead of willow tree material i used jute ropes. the jute ropes are tightly rolled over the pot to get an insulation cover. this will also gives a sustainable look to the pot.
Do it slowly for perfection.
Step 2: Making a Handle
The handle is also made using jute rope. first i took a metal string and warped over the edge pot and made two knots and inserted the rope through it.
Step 3: Adding a Blower Fan
Since i used a plant pot, it had a hole on the bottom side. So i thought of adding a small blower fan. for fan i dismantled my old laptop and taken the fan form it
Step 4: Modifying the Blower Fan
The fan works on 5v and produce required amount of air flow. but since its one side is opened , i have to add a pipe to direct the airflow.
i took a small pipe and sealed its one end by heating. the i took a blade and pealed it open correctly in the length of the fan. attached the pipe to fan using super glue. sealed all side using hot and we have a perfect air blower.
Step 5: Wiring Part
I have add a switch and a potentiometer for air speed controlling. soldered everything together and attached to the pot.
Step 6: Final Outcome
I chop down some hard wood into small piece and lighted the fire. The airflow system work correctly but since I used plastic pipe, the end started to melt slowly. Anyway since this is an experimental version, I learned somuch as a design iteration. For next version I will be making an exact design of kanger with metal pipes and 3d printed enclosures.
Thank you for reading and comment down your thoughts.
