Introduction: Portable Guitar Amplifier - DIY
Welcome To "Sam Technology Professionals"
Hi Guys..!!
This is a portable guitar amplifier with some exclusive function. It gives you clean sound, bright & loud sound and distortion guitar sound. Even if you connect a semi acoustic guitar it will work as it do. It is good for high impedance pickups and microphones as well.
________________________________________
Details :
It is based on two IC "LM386" and some capacitors and resistors. It works fine. Its is easy to build and you can do it easily within 30mins.
Components Required:
1 - Resistor 10 Ohm
2 - Capacitor 0.047uf [Code = 473J or 473k]
1 - Capacitor 100uf [ Voltage = 25v or 50v]
2 - Capacitor 10uf
1 - Capacitor 220uf [Voltage = 16v or 25v]
2 - IC LM386 [Its a Low Voltage OP Amp]
1 - Small Speaker
1 - Potentiometer 10K Ohm [Linear or Audio But i will prefer audio first]
1 - LED (use it in series with a 100 Ohm resistor)
1 - DC Power Jack [Or you can use a 9v battery clip if you want to fit the battery in it.]
Beside these components a piece of pref-board and box to fit the circuit in are also required.lol
If you have any question then ask me in comments. I promise to reply your every comment.
Build it now..!! Have a wonderful Day..!!
Hi Guys..!!
Details :
1 - Resistor 10 Ohm
2 - Capacitor 10uf
1 - Small Speaker
