Introduction: Portable HDD Grinder
Guys those who interested to make a simple grinder for small scale use can try this....
All you need is an old HDD, can be easily get from a computer shop.
Step 1: Parts Required
1. Old HDD
2. 230Ac - 12v, 2A circuit board (you can also use 12v,2A step down transformer or SMPS)
3. Emery Sheet
4. Push button type micro switch
5. SPST switch
3. Emery Sheet
5. SPST switch
Step 2:
Open the HDD & remove front cover,actuator & magnetic disc.
Step 3:
Now take the magnetic disc, cut same size of emery sheet & stick it on the disc.
Step 4:
Place the hdd & circuit board on a plastic box.
attach the push button switch & spst swich on the side of box.
Step 5:
HDD has a tendency that when there is no usage the spindle will automatically turn off. So to get a continues spindle rotation just short "reset & ground" pins on the ide port. To identify the pins look at the picture.
Connections from these pins are given to push button & SPST switch
Step 6:
Mount all parts on a plastic box & give connections.
