Introduction: Portable Workspace
Hi! This is my first instructable, I don't have pictures right from the start because I never thought about making an Instructable for it, and decided to do it when I had finished it. Nevertheless I'll try to explain everything. This is my take at doing a portable workspace using a PC Case.
BTW My english could need some polishing, so I apologize in advance if I make any mistake. (I'm from Mexico)
Step 1: Materials
You'll need:
- A Desktop computer case
- Your tools
- A power strip
- Any other thing you might want to take with you
In my specific case (since I am an electronics student) I used: - The PC Case
- Pliers, cable cutter, breadboard and multimeter (last one not shown 'cause I didn't have it with me at the time)
- Satellite radio (I love to work and listen to the radio at the same time)
- Power strip
- Soldering Iron and its base (I took the base and the screw with the wing nut from a soldering iron stand I bought at my local electronics shop, around $3 dollars)
- Speaker (Portable BT speaker w/ aux in for the sake of simplicity and time)
Step 2: Assemble Everything Together!
After you've chosen a suitable PC Case (In my case I had a small one, perfect to fit all I would every take with me) you'll want to assemble everything together.
Step 3: Satellite Radio Install
The first thing I did install was the SatRadio. Why? Because It's a hell of a mess to manage those long cables and if I did it last I would likely ruin something else, or just run out of space pretty quick. I've placed mine where the CD Drive would sit before.
Start by the antenna, since you'll need to place it somewhere clean (with no other wires making a mess) route the really long cable and organize it with zip ties.
Then secure the dock where your radio will sit, again, secure it with zip ties.
Connect everything and later on, organize the cables with, wait for it, zip ties.
Just one more thing, you'll want to put something in front o the SatRadio to protect it against scratches, debris and other stuff, just use some acrylic (in my case and because of the hurry, packaging plastic)
To operate it, I just use the remote.
Step 4: Soldering Iron Base
This is pretty straightforward, just use the screw and wing nut to attach the soldering iron holder to teh pc case through one of the holes in the front. To store it inside just reverse it.
Step 5: Power Strip
Just put it on the back side of the case, connect everything to it and stick the main cable out, either through a existing hole or drilling one yourself.
Step 6: Something I Did Not Do
Put organizers inside to hold your tools (pliers, etc). I did not do it yet, my drill is broken.
Step 7: Done!
To carry it: Just put the lids back on and take it with you :)
Just a couple improvements you can do on your own (I did not do themsince I dont have the tools required to make 'em at the time of writing):
Put organizers inside, mounted on the metal inside
Paint it to your liking
Put a handle on top (there are instructables available for your inspiration)
Mount internal speakers
Put acrylic in front of the SatRadio to protect it
If you come up with another improvement I didn't mention, please leave it in the comments! :D
Enjoy! Hope you liked it :D
