Introduction: Portable Circular Bench
Hi everybody, i had build a small circular bench, and i will give you my photos, drawings and my help to you build one too. This machine is cheap, around 50 euros and very helpful.
Let's start ;)
My Portuguese blog: www.logicamecatronica.com
Step 1: Material
For this project, this is the material that you need to build one small circular bench:
- wood (on next step you will see the size)
- wood screws
- one motor 220v 0,8HP 5.2A (you can use other with the same dimension)
- metal plate
- white glue for wood
- circuit breaker C6
The circuit breaker only will interrupt one phase of machine, the cable will connect direct at motor.
Step 2: Technical Drawings
This are all my drawings to construct of my circular bench, with this, you can reproduce every wood parts, you will need a drill driver and something that cut the wood like a another circular bench or a saw.
Step 3: Mounting Machine
With this 2 videos, you will see how can you assembly all the parts :) it's easy
Step 4: Photos of Machine
This photos are of many angles of my machine, with this you can ask questions and see how can you connect the cable at motor with circuit maker for example, if you have questions, ask me please.
Step 5: Video of Cutting Wood
Well, we come to the end, this small video proof that machine works without problems. I hope that you like, this project is easy to do, and like i said before, it is helpful. If you have anything that you don't understand, please ask me, i will answer and correct the article.
