Portable Speaker for All Music Players
42,987
28
77
Introduction: Portable Speaker for All Music Players
Make a really easy speaker
Step 1: Parts
you need:
a speaker (you can get them from tv's, jukeboxs, and more)
ipod head phones
wire cutters
soddering iron
sodder
Step 2: Cut the Head Phones
Now, take the ipod head phones. Cut the wire right beneath the bud part.
take the insulation off the wire.
Step 3: Connect the Amp to the Head Phones
On the back of the amp there should be two wires sticking out.
connect the stripped wires from the headphones to the ones sticking from the amp.
Be the First to Share
    • Big and Small Contest
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
    77 Comments
    erwin
    erwin
    8 years ago on Introduction
    Am I missing something? where is the amp is coming from?
    geo526468
    geo526468
    13 years ago on Introduction
    For those of you doing this with a large speaker i recommend making an amp of some sort so you don't blow out your ipod or mp3 player and render it useless.
    thedownsmeister
    thedownsmeister
    Reply 13 years ago on Introduction
    It is impossible for you to blow out your ipod by connecting a headphone jack to an unamplified speaker. The only thing that would happen is your battery would drain faster than normal because it's trying to drive a much larger speaker. I do agree that this won't work that well without an amp, though; you can see that in my first comment.
    Riktech
    Riktech
    .. many mp 3 devices can't work properly with a large speakers., if you put an 8 or 4 ohm you're almost to make a short cut in your mp 3 or audio device. size no matter but in the electronics devices the ohms Matter.... yeah is possible blow it using a large speaker because the left/right wires send an excessive positive signal to the device ground (almost Shortcut) and it could overload the internal circuits. everybody knows how to connect an speaker in to a wire. don't take a risk. take your time made an amplified speaker. i have many ideas to share but i need some time to made an instructable.
    thedownsmeister
    thedownsmeister
    14 years ago on Step 3
    Hey everyone, this might not be working because there is no amplifying circuit between the output (your ipod) and your speaker (the speaker you ripped out from something). If your speaker is any bigger than about 1" across you will need an amplifying circuit even with the volume turned all the way up as Derinsleep said. The ipod or any other music player will not have enough power to drive the speaker's movement, which creates the sound. I agree with JL2013; this instructable was very confusing and could have used some original pictures or video to help demonstrate what steps need to be taken.
    georion
    georion
    Roger Dodger !!!!!!!!! instead of worrying abut spelling--lets worry about if this will work !!!!!--great comment ,,thedownsmeister !!!!!!!!
    butterflycookies
    butterflycookies
    13 years ago on Step 3
    I connect a ton of speakers together and i need a small amplifier for them I gatta jack one from a cessite player or something....
    musick_08
    musick_08
    Reply 13 years ago on Step 3
    there is one at radioshack for about $25, idk how big it is, but i'm getting it when i get some money
    arikyeo
    arikyeo
     i doubt this is an 'ible. it just tells things we already know!
    wrongboi
    wrongboi
    13 years ago on Step 1
    Some of you guys can't even spell solder, how embarrassing.
    BlondGuy101
    BlondGuy101
    Reply 13 years ago on Step 1
    He's just spelling it phonetically, as per what I think must be the commonest American pronunciation. Chill
    cons11
    cons11
    is there a word "commonest"?are you saying "most common"?
    BlondGuy101
    BlondGuy101
    I did think that commonest is a real word, it is certainly common round my way. Most common probably would be the more correct though according to Henry Spooner's Ideal of English Grammar.
    LilPurpleCow
    LilPurpleCow
    Yeah, I don't get it. You connect earphones to a speaker, where does the mp3 go?
    creative zen
    creative zen
    14 years ago on Step 1
    where can i get a soddering iron, what is a sodder, and how much would they cost?
    TheMadTinker
    TheMadTinker
    Reply 14 years ago on Introduction
    You can get a soldering iron at your local electronics store (think Radio Shack). Solder is a metal alloy with a fairly low melting temperature used to connect wires and other electronic components.
