Introduction: Pose Estimation on the Raspberry Pi 4!
The goal of this project was to how well pose estimation could perform on the Raspberry Pi. Google provides code to run pose estimation on Android and IOS devices - but I wanted to write python code to interface with and test the model on the Pi.
Here's a demo if you want to try things in your browser and with JavaScript!
https://storage.googleapis.com/tfjs-models/demos/p...
Additional resources:
  • Raspberry Pi 4 GB
  • Raspberry Pi 5MP Camera (rev 1.3)
  • LED
  • 470 Ohm Resistor
  • Small breadboard
  • GPIO push button
  • 3.5 Amp USB-C Power Supply
Step 1: Clone the Repository and Change Directory
Command:git clone https://github.com/ecd1012/rpi_pose_estimation.gi...
Command:cd rpi_pose_estimation
Step 2: Open Command Prompt and Make Sure Pi Is Up to Date
Command:sudo apt-get update && sudo apt-get upgrade
Step 3: Install Virtual Environment
Command: sudo pip3 install virtualenv
Step 4: Make Virtual Environment
Command:python3.7 -m venv TFLite-venv
Step 5: Activate Environment
Command:source TFLite-venv/bin/activate
Step 6: Get Script to Install Dependencies
Download the following: https://github.com/ecd1012/rpi_road_object_detection/blob/main/get_py_requirements.sh
Command:bash get_py_requirements.sh
Step 7: Enable Pi Camera
Command: sudo raspi-config
Go to interface Options and make sure the Pi Camera is enabled.
Step 8: Grab the Sample TensorFlow Lite Posenet Model From Google
Command: wget https://storage.googleapis.com/download.tensorflow.org/models/tflite/posenet_mobilenet_v1_100_257x257_multi_kpt_stripped.tflite
Step 9: Connect Pi Camera Module to Raspberry Pi
Connecting the Camera for This Project: https://youtu.be/Zfmo3bMycUg
Step 10: Connect a Push Button to GPIO Pin 17
This will be used as input to kick off the program.
Connecting Push Button for this project: https://youtu.be/Zfmo3bMycUg?t=437
Step 11: Connect an LED to GPIO PIN 4
This LED will turn on to indicate when the program is running. Make sure you use a current limiting resistor with the LED!
LED Connection for This Project: https://youtu.be/Zfmo3bMycUg?t=353
Step 12: Running Pose Estimation
After all your hardware and software is configured correctly run the following command:
Command: python3 TFLite_pose.py --modeldir notebooks/posenet_mobilenet_v1_100_257x257_multi_kpt_stripped.tflite --output_path pose_images
Where the --output_path you specify is where you want images saved.
The script will start running and wait for you to press the GPIO input button to start processing the video feed from the camera. Once you press the button, the green LED will turn on and the pi will start feeding and processing the video stream through the neural network. Processed images will be saved to the '--output_path' you specified over the command line, with a timestamped folder for each button press.
Step 13: Test It Out for Yourself and Enjoy :)
