Introduction: Pour Over Coffee Maker
I made this coffee maker for temporary use after ours broke but seeing as that was a few months ago it has no problem being used for long ish term use.
I made this from:
-pallet wood
-1" screws
- a funnel (the size of a coffee filter)
I made this from:
-pallet wood
-1" screws
Step 1: Measure Materials
I made this from pallet wood and some 1" drywall screws but nails should work too
It is about a 12" and has a 7" long base.
The top horizontal piece is 5" long and should be high enough to put your mug under. I made mine to fit anything as tall as my thermos but it is to narrow for a coffee pot.
Step 2: The Funnel
A hole should be drilled in the top horizontal piece for your funnel to rest in. Mine was a 1" hole and I used router bit to round the edges
Step 3: Make Your Coffee
The way I make my coffee I to put my filter in the funnel, put my coffee grounds in it, boil a kettle of water, and the once the water is hot I pour it over slowly as not to over fill it.
Step 4: Notes/thoughts
the first cup is typically the best after wards the filter begins to get with the grounds and it takes longer.
This is ideal for the people who only make one cup. You can make however much you like
Please comment/ suggest
