Introduction: Powder Scoop
This scoop will allow you to take a scoop of your drink power preference and insert it directly into the water bottle.
Step 1: Tinker Cad
Go to https://www.tinkercad.com and create an account to start your design
Step 2: Base
Take a cylinder from the toolbar
Step 3: Base
Get another cylinder and shorten the height to act at the base
Step 4: Base
Take a "hole" cylinder and place it in the middle of the solid cylinder, then highlight them and press the "group" button in the top right
Step 5: Base
Put the base under the other piece and highlight+group
Step 6: Top
Drag a cone and "hole" cylinder onto the plane
Step 7: Top
Take the "hole" cylinder and put it in the middle of the cone then highlight+group
Step 8: Top
Take another cylinder and "hole" cylinder onto the plane. Put the "hole" cylinder in the center of the solid cylinder the highlight+group. Shorten that shape and put it in the previously made cone.
Step 9: Scoop
Put the cone up top of the base scoop
Step 10: Handle
Group the cone and base together. Drag a one solid box and one "hole" cylinder onto the plane. Shorten the solid box into a small rectangle. Shorten the width of the "hole cylinder" so it becomes an oval then move it to the center of the rectangle and highlight+group.
Step 11: Scoop
Take the base plus the handle and highlight+group them. Then you can change the scoop whatever color you choose. You can also change the length and width to your preference.
