Introduction: Power Antenna Hack
Hello! friends
Welcome to my 2k16 DIY "Power Antenna Hack" project. In this project i'm gonna show you how to make your own power antenna at home with the help of this you can easily boost your internet devices signals like wingle etc. It's really easy to build.
So, let's get started.
Step 1: Material
You'll need
Cotton Buds (empty box)
Antenna with connector
Aluminium foil
Vernier Caliper, scale or any other measuring tool
Hot glue
UHU
Step 2: Size Measuring
Take a vernier caliper and measure a anteena's size from the bottom as you can see that in a pic.
Step 3: Making Hole
I just make a rough hole according to the size of antenna but you can do it better.
Step 4: Aluminium Foil Fitting in a Box
Now cut the aluminium foil according to the inner size of the box and then paste that foil into the box with the help of UHU like i do.
Step 5: Antenna Fixing
Now take an antenna and pass it through a hole and make sure just left the 3 inches from bottom where it bend from because sometime you'll need to change the direction of it. Put some hot glue at the end of the box (according to the pictrues). It's look like this.
Step 6: Installing a Connector
Now connect a connector with anteena.
Step 7: Finish
Now your power antenna is ready to use.
I hope you guys like it.
