Introduction: Power Bank
Hello! friends
Welcome to my another rechargeable power bank. In this project i'm gonna show you how to make your own power bank by using car charger.
So let's get started.
Step 1: Circuit Diagram
With the help of this circuit diagram we can build our own power bank.
If you are using simple 9 volt battery you just follow the second picture of circuit diagram.
If you are using rechargeable battery then follow the first picture of circuit diagram.
Step 2: Material
You'll need
A car charger
9 volt recharable battery (but i'm using simple to just show you)
9 volt battery jack
Switch spst
1n4007 diode
330 ohm resistor
Red led
Female pin connector
Data cable
Jumper wires
Hot glue
Step 3: Disassemble
Open your car charger very carefully and take a circuit from it and remove the all other parts.
Step 4: Soldering
Take a circuit board of car charger and soldering the +ve and -ve with piece of wires.
Step 5: Making Holes
Make some holes according to your fitting.
Step 6: Fitting
I'm just using simple 9 volt battery (don't plug the charger) but i replaced it with recharable 9 volt battery later. Fit the all components in a box make sure all connections are working properly according to the circuit diagram and put some hot glue on a components. Now your power bank is almost ready to use.
Step 7: Finish
Now connect the data cable with your power bank and then connect the other side of the data cable with your smartphone push the button "ON" you can see charging is started of your phone.
Another benefit of this power bank is you can also connect your usb internet device (Wingle) with it.
I hope you guys like it.
I'm sorry about previous pictures its really dangerous. I never connect a li-ion battery in series again. If i need to connect a li-ion cells in series i definitely use a balancing circuit with it. I really thanks to my instructables friends they were help me alot show me a right path of using li-ion battery.
Again thanks you guys are awesome......;)
74 Comments
8 years ago
how would you recharge the 3x18650?
Reply 8 years ago
Jboneymyhomie power bank required to 12 volts for charging.
Reply 8 years ago
This is a dangerous way to attempt this with the circuit you've provided. When charging Li-Ion or Li-Po batteries in series, you must include a balancing circuit and supply only 4.2v max to prevent overcharging and/or overheating your batteries.
Battery packs that contain multiple cells in series (such as laptop batteries) have the balancing circuit and everything else built in to them.
You could always charge them one at a time, but you'd still need to keep an eye on them using a voltmeter to ensure they didn't overcharge.
Be cautious with these types of batteries, they can explode and burn you or your house down if you're not careful.
Reply 8 years ago
Don't let the CyberSafetyNannies deter you from sharing great projects such as this... They are always around ready to piss on your ideas..
Reply 6 years ago
Go away troll, please...
Reply 6 years ago
THERE IS SOMETHING WRONG WITH YOU!!.. IT HAS BEEN 2 YEARS AND YOU ARE STILL BITCHING ABOUT THIS?? GET A LIFE!!.. BULLY!!!
Reply 8 years ago
In no way did I try and deter him from sharing his project, I simply tried to warn him of the dangers he could face. It's a great project to learn the ins and outs of batteries, charging and so forth. Maybe he'll get lucky and manage not to hurt himself, maybe not. A balancing circuit would ensure that he didn't. Sharing this is how you learn, and sometimes people offer advice in order help it progress. That is what the site is all about, yes?
Before mud slinging and name calling you should have working knowledge of the topic at hand. Don't take my word for it, Google "charging li-ion batteries in series" and see what you come up with. Maybe then you can actually contribute to the discussion instead of coming off as childish and ignorant. The CyberSafetyNannies could possibly save you from a trip to the emergency room, or at least give enough pause to research a little in contemplation before charging blindly ahead.
Reply 7 years ago
That IS trying to deter him
Reply 6 years ago
No that was respectful warning to those who might duplicate something that is faulty in design and is very real hazard. In the event that would deter someone from posting their projects, they are to thin skinned to be posting in the first place. Perhaps you may do well to be quit and learn from those who could teach you something. As the person who posted this projectdid, as any intelligent person would. Kudos to the author for being one of those intelligent persons and editing their post
Reply 7 years ago
Reply 7 years ago
Reply 8 years ago
I stand but my original post...
Reply 8 years ago
it's a good idea, but needs some modifications so it doesn't blow up in your face
Reply 8 years ago
kaddigart thanks for updating me i like to make a circuit of balance charging fix it with my power bank in next version.
Reply 7 years ago
LawrenceH8 is just overreacting
Reply 8 years ago
Cool, as long as you're aware of the dangers.
Reply 8 years ago
DANGROUS is an understatement! Under no circumstance should you use LI batteries! Nicad (poor choice) or NiMh would be OK with a #47 bulb as a current limiter (6.3volt 50ma). LEHenson.com AE6JI.com
Reply 8 years ago
I also don't see any type of balancing connections for the batteries. This is a dangerous instructable.
8 years ago
I tried this, and the charger disintegrated halfway through step 4.
Reply 6 years ago
Then that was a charger that probaly wasn't safe to use for it's intended use. Baran bi cgargers should feft in the bin
