Introduction: Power Bank Under $10 ! | DIY | 3D Printed
So let’s get started.
Step 1: Watch the Video !
[Play Video]
If you get bored of reading you can watch my video on Youtube
Step 2: Everything We Need
Here is everything, which we are going to need:-
a. Soldering iron
https://www.gearbest.com/soldering-supplies/pp_314...
b. Strippers
https://www.gearbest.com/pliers/pp_591318.html?lki...
c. Powerbank module, I got mine from aliexpress for around $1.50
https://www.aliexpress.com/item/Dual-USB-18650-Bat...
d. 18650 cells you can savage these from old laptop battery of buy some
Step 3: Soldering !
first check the voltage of each cell if all are same then, start soldering 18650 cells in parallel
After soldering, fix cells together with the help of hot glue gun
After which solder the battery to the module and you should be able to use it
Step 4: Need Case !
We need some kind of case, for that I used my tevo tarantula to 3D print one
Which I designed in fusion 360 You can find all my files below or else you can always use your own creativity to make one
Step 5: Put Everything Together !
Then I added new push button because old one was not convenient for the design of case soldered it into the place.
Then just place everything inside the case seal it up with hot glue and we are done !
Step 6: Thank You
If you like my work
Feel free to check out my YouTube channel for more awesome stuff: https://www.youtube.com/c/Nematics_lab
You can also follow me on Facebook, Twitter etc for upcoming projects and behind the scenes information
https://www.facebook.com/NematicsLab/
