Introduction: Power Booster Recycles Dead Battery
This power booster recycles a 'dead' battery to power a 1.8 volt red LED light. It's mainly made from recycled parts. The inspiration came after building an 'Everything is OK alarm' which used the same principle - a rapidly collapsing magnetic field inducing a power boost to a LED Circuit. As a bonus, it's sure to make for a splendid minimalist Christmas tree.
1.8 volt red LED
'Dead' 1.5 volt AAA battery
Small 1.5 volt buzzer
Windings from a burnt out toy motor
Bamboo skewer sticks
Tools:
Soldering iron
Hot glue gun
Step 1: New Vs 'Dead' AAA Batteries
Step 2: How to Increase the Voltage
If a LED is connected across the battery which doesn't have enough volts to power it, no current flows and the LED doesn't shine.
But if you combine both circuits you can get a boost to the LED circuit from the induced current as the wire from the first circuit is disconnected from the battery and the LED will flicker. Then if the first circuit can be rapidly turned on and off the LED is likely to appear to be constantly on, maybe with a flicker here and there.
This project attempts to test this using the winding from a broken toy motor to create the first circuit and a small buzzer to create a switch which rapidly turns the circuit off and on. The aim being to have a LED glow constantly from a recycled 'dead' battery.
Step 3: Testing the Theory
A 1.8 volt red LED was connected across a battery with 1.2 volts remaining, as expected it didn't light the LED.
Another wire was then connected from the battery to the windings from the dismantled toy motor (to increase the magnetic field in the wire) and then to the battery to complete the circuit. When the wire was disconnected from the battery the LED flickered on. A previous project using a beer can also demonstrated this phonomime
Next the buzzer, with its cover removed, was added to the setup. The buzzer (surprisingly) would run off the 1.2 volts from the battery and was set buzzing away. Another wire was connected between buzzer body and battery so when the wire from the windings circuit touched it, the windings circuit is completed and a magnetic field created. By holding the wire from the windings circuit just above the vibrating buzzer 'striker', the windings circuit was rapidly turned on and off (building and collapsing its magnetic field) and by doing so caused the LED Circuit to have enough volts for the LED to appear to be constantly on.
Step 4: Assembly (Part 1)
- Connect a switch to a battery holder. A soldiering iron and hot glue gun assisted with this.
- Make a small pyramid above the battery holder using 4 bamboo skewer sticks secured with hot glue.
- Soldier on a 1.8 volt red LED at the top of the mini Christmas tree.
- Test the LED glows with a new battery (1.6 volts)
- Test the LED doesn't glow with a dead battery (1.2 volts)
Step 5: Completed Assembly
- Add in the buzzer circuit, along with a switch.
- Add in the windings circuit - to touch the striker of the buzzer a little copper foil was added.
- Insert a dead battery (1.2 volt) with the buzzer circuit turned switch off - the LED will not glow but when the buzzer circuit is switched on the Red LED lights up.
