Introduction: Power Brush - Drill Attachment
It all started when I had to clean the shower. 'Surely,' I thought, 'someone else, who hates cleaning tile, has made a brush head for a drill.' Well, no one had. Or, at least, they figured it was so simple no one would need an instructable for it. So I made one without an instructable, and now I'm making an instructable for those who don't want to try it without instruction! So there you go. Super easy, super cheap, super fast. That's my kind of project!
Step 1: Materials
This is all your going to need:
-A large screwdriver
-A 'Soap Dispensing Palm Brush' refill pack
-A 1/4 in. x 1 1/2 in. machine screw and nut. You may need a different diameter screw if your brush is a different brand.
Step 2: Assembly
Screw the machine screw almost all the way though the hole from the bristle side. Leave a few turns left to screw before threading the nut on. Tighten the nut with your fingers into the countersink around the hole. Then tighten the screw with the screw driver. If your brush doesn't have a countersink, don't worry about leaving a few turns before threading the nut, and just tighten the whole thing down.
Step 3: Use It!
Just put it in your drill like a normal drill bit and start scrubbing! Just, please don't use this on anything fragile or of real value. (Like if you have antique tiles for some reason.)
