Introduction: Power Supply for Etching With Salt Water
Make a "cheap" power supply for etching metals with salt water.
Step 1: The Gathering
Gather up the materials you need. My son who tattoos, had an extra power supply he gave me. I bought two 1/4 inch phone connectors, two small alligator clips, and had a piece of two strand wire I salvaged.
Step 2: Close the Gap
Tools/Material
Two Stand Wire
One 1/4" Telephone Connector
Electrical Tape
Soldering Gun
Solder
Flux
Wire Cutters
Cut a small length of wire (about 1 1/2") and strip about 1/2" off both ends of one of the wires to expose the conductors. Take the phone connector apart and solder one end of the wire to the tip and the other end to the ring of the phone connector. Then wrap the exposed wire with electrical tape and screw the phone connector back together.
I was going to integrate an on/off switch but found it was unnecessary.
Step 3: Plug It
Tools/Material
Two Strand Wire
One 1/4" Phone Connector
Wire Cutters
Length of Two Strand Wire
Take apart the second phone connector, slip the cover over one end of the wire. Cut the exterior insulation of the end of the wire, back about 2 inches, and cut the insulation of both strands back about 1/2".
Step 4: Solder It
Tools/Material
Electrical Tape
Soldering Gun
Solder
Flux
Solder one end of the white wire to the tip, and of the black wire to the ring. Rap one of the soldered wires with electrical tape to stop arching. Put the phone connector back together and screw on the cover.
Step 5: I Feel Exposed
Tools/Material
Wire Cutters
Take the wire with the phone connector attached to it and cut of the exterior insulation back about 18". Cut the insulation of both stands about 1/2".
Step 6: Clip It
Materials/Tools
Two Small Alligator Clips
Soldering Gun
Solder
Flux
Needle Nose Pliers
Solder and crimp one alligator clip on each end of the exposed wires. The maximum current that will be going though the wires will be 15 volts, so there is no need of covering any exposed wires.
Step 7: Etch It
Plug the first phone connector with the single wire into the jack marked foot peddle. The foot peddle on a tattoo power supply acts as a on/off switch. The first phone connector wired will close the circuit, and ensure a constant power supply to DC Out jack. Plug the second phone connector in the DC Out jack, and you are ready to etch.
With the picture of the finished product, is a knife I etched my mark on using salt water and 9 volts.
(Test your wires to see which is your positive. I found that my black wire is positive)
