Actually you should not use the pot at all. It is inefficient, cannot supply much current, and does not regulate. Use a regulator or just stick to rated voltage. A pot should generally be used only for a fixed, know load, and after the revelant equations for power and voltage are checked.
You might find a 50ohm rather than 50kohm pot more effective and give wider control stability but as you stated a linear regulator would be far superior
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
3 Comments
russ_hensel 10 years ago
gmeadows3 10 years ago
ihemkes 10 years ago
Correcto! i changed it. Thank you.
