Power Washer Art
Intro: Power Washer Art
Spring is finally here. That means it is time to power wash the sidewalks. But there is no reason why you can't have some fun in the process. In this project, I am going to show you several ways that you can draw pictures on sidewalks and buildings using a pressure washer.
STEP 1: Watch the Video
Here is a video walkthrough of the project.
STEP 2: Materials
Here are the materials and tools that you will need for this project.
Materials:
Stencils
Duct Tape
Chalk
Tools:
Pressure Washer
STEP 3: GET PERMISSION!
The first and most important step of this project is to get permission from the property owner. If you don't get permission, you can get in real trouble.
You might think that because power washing a sidewalk won't cause any "damage" to the property, you can't get in trouble for it. After all you are making the surface cleaner. But depending on the laws in your area, you might still get arrested for it.
At the very least, if the property owner doesn't want your art work there, they might erase all your hard work. So get permission first.
STEP 4: Select a Location
Next you need to select a specific location for your artwork. There are a number of factors to consider when doing this.
You need to have access to a water hose and electricity.
The surface needs to have a lot of embedded dirt so that your drawing will stand out. It also helps if the color is relatively uniform.
Smoother surfaces will allow you to make finer details. It is also easier to adhere tape to smooth surfaces. However, it is more difficult to be precise with very smooth surfaces. When you spray the target area, the water will spread out when it hits the surface and it will also clean off the area immediately around it. This is less of an issue with rough surfaces because the water is scattered by the surface texture.
Sidewalks are plentiful and easy to work with. But keep in mind that people will be walking all over it. So your drawing won't last as long.
With all this in mind, find the best location that fits your needs.
STEP 5: The Basic Process
The process of drawing with a power washer is very simple. You use high pressure water to spray a dirty surface. This cleans off target area and leaves it much lighter than the surrounding dirty area. This process is sometimes called "Reverse Graffiti."
There are a number of ways that you can create this kind of art work. In the next few steps, I am going to give a few examples.
STEP 6: Create a Freehand Drawing or Message
The simplest way to make power washer art is to just make a freehand drawing. You can also just write messages. You can write poems or just say "Have a nice day." This method is simple but it can be very difficult to make it look nice. If you are not a good freehand artist, I recommend using some kind of guide such as a stencil.
STEP 7: Use a Chalk Outline
One way to make it easier to draw with a power washer it to follow a chalk outline. First draw the picture in chalk. It is much easier to be precise when drawing with chalk because you can take your time and make subtle changes. Press firmly on the chalk so that it gets down into the groves of the sidewalk.
Then go over the chalk outline with the power washer. Start on the far edge of the drawing and carefully work your way to the opposite side. The chalk will wash off as you go, but you should still be able to see where the lines go. Just focus on the general shape for the first pass. Once you have the rough outline completed, you can go back over it to fill in any solid areas and adjust the line thicknesses.
If you or your kids like drawing with chalk, this can also be a great way to make their drawings last longer.
STEP 8: Make an Outline With Tape
Another method is to make an outline on the surface with tape. This will shield the surface under the tape and let you clean around it. The tape should leave a sharp line around the edges of the outline.
Duct tape is the best kind of tape to use for this. It is tough enough to withstand the force of the pressure washer. It is also good at sticking to most surfaces.
One problem that you may encounter is the tape coming off the surface. Here are a few things that you can do to help prevent that. When power washing over the tape, point the sprayer so that the water goes away from the tape. This will help to keep the tape down. Spraying towards the tape can lift it up off the surface. It may also help to hold the nozzle farther away from the tape or to use a wide sprayer. You can also spray in short burst when working around the edges, but don't do this too much because it is bad for the motor.
Once you have the letters clearly defined, you can remove the tape to apply the finishing touches and to clean off the surrounding areas.
STEP 9: Make a Stencil From a Printed Out Picture
You can also make stencils from printed out pictures. First find a picture that you like. Keep in mind that with this kind of drawing you can't use color. So find a grayscale image. If you want to make your favorite cartoon character you can often find coloring page images of them.
Then blow up the image as big as possible and print it out on multiple sheets of paper. The larger the images is, the more visible the details will be. Cut out the individual pictures and tape them together.
Then attach the image to your stencil board. The best kind of material to work with is thick plastic. But poster board can work if that is all you have. Just keep in mind that a power washer can easily rip through paper products like poster board. I didn't account for this on my first attempt and I had to do a lot of work touching up picture after I removed the stencil. The best way to handle this problem is to apply duct tape to all the edges of the stencil. You may also want to use a wide sprayer nozzle so that the pressure isn't quite as high.
Once you have the image transferred to the surface, you can remove the stencil. You will probably need to touch up the picture a little afterward.
STEP 10: Make a Wood Stencil
If you want to make a stencil that is sturdier you can make it out of wood. Just trace the shape onto a board. Then cut it out with a jigsaw. Place the wood stencil onto the surface and pressure wash around it. Most construction boards are tough enough to withstand power washing. So you can spray right up to the edge of the stencil. This will give you the sharpest lines. These stencils will also last a long time and can be used over and over. You can even make larger designs with repeating patterns.
STEP 11: Use Other Patterned Objects As a Stencil
You can use just about anything that has an interesting shape as a stencil. For instance, I had a rubber door mat that had a nice decorative pattern on it. So I decided to use that as a stencil. I just power washed in the grooves between the lines of the pattern. Then when I was done, I just slid it over and made the same pattern again. You can replicate this as many times as you want. The result is a regular repeating pattern on your sidewalk.
STEP 12: Have Fun
This project is a lot of fun. It lets you draw, and play in the water. All this with the excuse that you are cleaning. It is a great activity for hot summer days. So try it out and have fun.
11 Comments
ucandoitcraft 8 years ago
Wow!
jdonato 8 years ago
EvolvedAwesome 9 years ago
Lots of fun!
lime3D 9 years ago
"But depending on the laws in your area, you might still get arrested for it."
Where would you possibly be arrested for this?
madenairy 9 years ago
the uk - technically this is criminal damage & if the officers concerned are behind on their arrest numbers and / or their in the mood...
DIY Hacks and How Tos 9 years ago
https://theactivesoul.wordpress.com/2013/08/11/interview-with-moose-the-inventor-of-reverse-graffiti/
I just want people to know that you can get in trouble for doing this before they try it.
stephenmack 9 years ago
This reminds me of this ible!
https://www.instructables.com/id/How-to-make-Rain-Drawings-with-NeverWet-superhydro/
ignoresliced 9 years ago
great
Orngrimm 9 years ago
is that the guy from XKCD @ http://xkcd.com/1110/ ?? Nice! :)
Yes it is. I'm surprised that someone go that reference. You even got the right comic.
NathanSellers 9 years ago
