Introduction: DIY Battery: Power an LED Flashlight With Pocket Change!
In this article, I will show you how to replace the typical 3 AAA battery pack in common cheap LED flashlights with pocket change to power the flashlight in a pinch. The battery created will even fit right inside where the normal battery pack should go! We've all seen these cheap little multi-LED flashlights at gas stations, convenience stores, dollar stores; you probably have one or more lying around. Let's get hacking!
What we will be creating is a voltaic pile, named for its inventor, Alessandro Volta in 1800. Our pile battery will consist of cells created from a US penny, cardboard, a US nickel, lemon juice, and salt (not shown in images). Another item not shown was a piece of glossy card cut from an advertising mailer. I didn't think of it while shooting the images, but used it to encase the battery and make it fit the flashlight better. I chose coated, glossy card for this as it will not readily absorb our electrolyte.
The lemon juice is an acid which acts as a catalyst to enhance the reaction, to it we add sodium chloride (table salt) to reduce the internal resistance of the battery. We will cut thin cardboard pieces to the size of a penny, soak them in the acidic electrolyte, and sandwich them between nickels and pennies. It just so happens that the 3 AA battery packs common in cheap LED flashlights are just a tiny bit smaller than a US nickel, which is why I chose this arrangement.
For those who want more chemistry information:
A galvanic voltaic cell contains two metals which are dissimilar in electrical potential, separated by a thin barrier. To this cell we then add an electrolyte which causes the electrochemical reaction to occur. The metal contains cations, ions heavy with protons; cations react with water containing anions (electron heavy). While one metal causes the reduction of oxidation in the other, the reaction of anions and cations create an exchange of electrons - an electric current.
Be sure to vote for this Instructable in the Make It Glow contest!
On with the show!
What you need:
Note: the number of coins and spacers needed will vary depending on many factors, you will need to adjust them depending on what the output of your cell measures. Just remember they should be dissimilar and alternating. If you are not in the US, check to see what metals your coins are made out of and use two with a different electrical potential such as zinc and copper.
On with the show!
What you need:
- US Pennies (copper plated zinc - we want the copper here)
- US Nickels (25% nickel, 75% copper - we are utilizing the nickel content)
- Lemon juice or another acid such as strong acetic acid for cleaning coffee pots
- Table salt (sodium chloride)
- A sharp knife
- Thin cardboard or similar material
- Electrical tape (vinyl)
- Multimeter or another device to measure output voltage
Step 1: Preparing the Barriers
We must prepare the barriers which will sit between the nickels and pennies in our pile. With a sharp knife, like an X-Acto knife, carefully cut some thin cardboard or similar material to the size of a penny. How many wafers you must prepare depends on how many coins you end up needing. This amount may vary due to a number of factors. If you end up needing too few to make your battery long enough for the flashlight, simply stack nickels without barriers on the end to fill the space. I chose the backing of an old notepad for my material. Select something thin, stiff, and absorbent. These wafers will hold our electrolyte and keep space between our metals to prevent short circuits which will reduce efficiency. Even blotter or filter paper works, but I've had better luck with cardboard.
If you're young, clumsy, or for any other reason think you might have problems then please do this with supervision or ask for help. It is far less embarrassing to ask for help than to cut yourself badly and have to explain to a trauma physician how you managed to hurt yourself. Cost of this project will rise exponentially if medical expenses are incurred.
Step 2: Preparing the Battery
A battery is a group of cells; each cell is a pair of metals separated by a barrier saturated with an electrolyte. Our cells will consist of a nickel, a cardboard disc, and a penny. The nickel will be our anode (+) and the penny our cathode (-).
Take your cardboard wafers and thoroughly soak them in a solution of lemon juice or other acid with a small amount of sodium chloride mixed in. Begin stacking your cells (nickel, cardboard, penny, cardboard, nickel...) and measure the voltage with a multimeter. Continue building until you reach about 3.5 volts, the equivalent of three 1.25V AA batteries.
If your stack becomes taller than the original battery pack height then clean your coins, try stronger acids, or use thinner barriers. Some experimentation may be necessary.
If you end up with a highly efficient stack which is too short, then simply stack nickels on the anode side until it fits. This will add some resistance, measure final result.
Once you have reached the desired voltage from your battery, wrap it in something non absorbent to keep it contained and stiff. I used a cut piece from a glossy advertising mailer, as mentioned in the introduction. Check to make sure the battery will fit the flashlight and make adjustments as needed. When done, wrap the battery in vinyl electrical tape from top to bottom, leaving only the center of the end coins exposed to make contact inside the flashlight. Check again to ensure everything is still working after assembly.
Remember that the cells will produce less electricity as the electrolyte evaporates. Keep them moist.
Step 3: Conclusion and Results
Install the battery in your flashlight, making sure it isn't wet or leaking and taking care to install it with the correct polarity. Once installed your flashlight should function! Congratulations, you have replaced your flashlight battery pack with pocket change. Your friends won't believe you, so be sure to record it and show them. Refer back to the introduction for how and why this works.
If you are having problems, make sure you don't have shorts in the cells (coins touching), your electrolyte is conductive and acidic or basic, and that the battery fits properly in the compartment. Check polarity, remember the cathode (-) is the penny side. If you look closely in one of the attached images, you'll see I forgot too. :)
Make sure you rate this instructable for your fellow users! Every time you rate an instructable it helps the entire community.
Remember to vote for this Instructable in the Make It Glow! challenge. We just made something glow (blindingly) with spare change! Also, vote in the Pocket Sized Contest, since it is pocket sized, as is the flashlight, and it uses pocket change. Also entered in the Mad Science Fair.
Thanks for reading, be sure to comment and subscribe for more cool hacks.
