Introduction: Powerduino - 1$ Powerbank
Power bank have become a very useful in today's world.
There are many variety of them available in market .
i have been using a Xiaomi power bank which costed me 1000 INR i.e 14$.
It is really good but as a Maker i wanted to make one.
Recently i completed this project.
1 $ Power bank
Special thanks to my friend Vrajesh , without the enclosure was not possible
[He donated this for operation ]
NOTE This has been eligible in hack your day and hand tools contest :D
Specification
- 2200 mah
- Rechargeable
- 1 A output
- 1 $ Cost
List of item required
Step 1: Salvaging Laptop Battery for Free Battery
Ok the 1 $ is only possible because i got so many free batteries from my old laptop battery.
Please pardon me the photos are not so good as i clicked in a rush ,i actually cut my finger while trying to open it.
OK to salvage batteries you need to have some
Preacaution
(1) Misusing the battery may cause the battery to get hot, rupture, or ignite and cause serious injury. Be sure
to follow the safety rules listed below:
- Do not place the battery in fire or heat the battery.
- Do not expose the battery to water or salt water, or allow the battery to get wet.
- Do not solder directly onto the battery.
- subject it to strong impacts or shocks.
- Do not pierce the battery with nails, strike the battery with a hammer, step on the battery, or othewise
- Do not carry or store the batteries together with necklaces, hairpins, or other metal objects.
- metal object (such as wire).
- Do not connect the positive terminal and the negative terminal of the battery to each other with any
- Do not install the battery backwards so that the polarity is reversed.
(2) Do not disassemble or modify the battery. The battery contains safety and protection devices which, if
damaged, may cause the battery to generate heat, rupture or ignite.
(3) Do not place the battery on or near fires, stoves, or other high-temperature locations. Do not place the
battery in direct sunshine, or use or store the battery inside cars in hot weather. Doing so may cause the
battery to generate heat, rupture, or ignite. Using the battery in this manner may also result in a loss of
performance and a shortened life expectancy.
Step 2: Soldering Wire to Battery
Soldering Li-Ion is a big problem even for the more experienced techs out there.Many try to solder Li-Ion cells or phone batteries. It is not advised by the battery manufacturers to heat them up regardless the reason.By using heat on Li-Ion cells, you can damage the plastic separator, pressure protections or even the main internal lithium layers.
Speaking of physics…heat requires time to transfer. Yes, thermal damage amount depends on the materials quite a lot, but the key to not overheating components or, in this case, Li-Ion batteries is the limited heat exposure time.
if your soldering iron takes quite a lot to heat up (30 sec +), remove it’s tip in favor of a thinner one. A 1mm wire tip will heat up significantly faster than a 2mm wire tip. Do not exaggerate though. If it’s too thin, it will melt.
I had to apply and remove quickly to avoid damage. Using pointed Tip is also better
Step 3: Preparing the Boast Converter
The lithium ion batteries hav a voltage of 4.2 in the full charge state and 3.0v on discharged condition .
So we need to regulate the output with a 5V regulated as Phone need 5 V to charge.
To provide the regulated 5V DC output we need a boost converter.
What is a Boost converter ?
A boost converter is a DC-to-DC power converter with an output voltage greater than its input voltage. It is a class of switched-mode power supply (SMPS) containing at least two semiconductors (a diode and a transistor) and at least one energy storage element, a capacitor, inductor, or the two in combination. Filters made of capacitors (sometimes in combination with inductors) are normally added to the output of the converter to reduce output voltage ripple.
Boost converters are easily available and they are cheap i bought a 1A 5V Boast converter.
NOTE :
Power input is equal to power output
Input Voltage x Input Current = Output Voltage x Output Current
The Boost converter has two input just input + and input -
Be careful with polarity
Step 4: Making the Case for USB Out
The Enclosure should be of a mouth freshener but i actually forgot the brand which it belongs.My friend was having it when i saw it and rushed to him.He said that he finished all .To his surprise i came for the enclosure not the mouth freshener :P.He Donated This for a noble cause.
The Cap was best for the USB female Out .
I started by drilling a hole of 3.2mm i max i had with my Dremel.
Then i using grinding bit i started to remove the left and right portion of the holes to fit the USB.
Later i realize silicon carbide is better for the job .
So i changed the bit and it worked.
I didn't had the files with me so there was a little imperfection but the USB fits perfectly in that.
Step 5: Adding Recharging Pin
Ok i Admit i can use the 4056 module directly.
But i didn't do that as i have a single charging module for now and many Li -ion battery so i made two pins to be used to charge the battery .
the connection are given in the previous step.
i had to mark the polarity on header confusion can burn the whole face.
I actually used a long male header pushed it to make equal on each side.
the top is outside and the bottom is inside the enclosure.
The inner connector connects to female connector which can be removed easily.
thus can be troubleshooted easily
Step 6: Adding Turn on Switch
Lastly the most important thing, we need a switch to turn on and off the power bank.
This was done the same way the USB part was done.
Only challenge was to make a the switch tightly fixed
i tried a lot of configurations and then settle for the inside outside configuration.
rather than pulling the switch from inside i pulled the wires solder it and then pushed the switch and it firmly fits in the enclosure.
Lastly lets calculate.
Battery 0$
Enclosure 0$
Boost Converter 0.9 $
switch 0.05$
Total 1$
Me and Amit are working on some very cool projects do follow us to get updates :D
Also like my page for support
https://www.facebook.com/makewithRex
Further Improvement
- Under voltage regulator
- Solar charging
- Short circuit protection
If any suggestion are there do say
Full Spectrum Laser Contest 2016
Make a Box Contest
Hand Tools Only Contest 2016
Hack Your Day Contest
85 Discussions
4 years ago
It all makes sense I am slightly concerned with the recharging idea. When the battery does need to recharged, what do you attach to the recharging pins to recharge it?
4 years ago
Hi. I was just wondering. If you are using unprotected li-ion cells (and those from a laptop battery most certainly is), you have to have some protection circuits in place. Li-ion cells will die if overdischarged, and can catch on fire or even explode if overcharged. Charging a dead cell can also be dangerous. A simple DC-DC converted doesn't have any of those protection circuits. I do not recommend to try this. Sorry if I misunderstood something. Waiting for a reply. :)
Reply 4 years ago
I think they have kept the charge circuit external so that can use one circuit to recharge a number of banks, which is why they have the two pin connector. Not a bad compromise for efficiency as long as they don't try and bypass it.
Reply 4 years ago
That is true, yes. But I'm not talking about charging the battery. I'm saying that there is no overDIScharge protection. Basically, if you drain the battery too much, IT WILL DIE. So you need some protection circuit to take care of that. :)
Reply 4 years ago
there is one cool thing to help lipo protection module that can help , i didn,t need to apply that because my power bank is used for arduinos mostly.in industry they have dedicated chips but those are not easily available or expensive for for one piece . So you can buy that
Reply 4 years ago
this boos converter has a minimum voltage of 3 v which mean under
3v it cuts off
if your boast doesn't have one try using zener for protection
Reply 4 years ago
I was not aware of this. If it actually works as you explained, then everything's good. Nevertheless, people should know about dangers of using unprotected li-ion cells.
Reply 4 years ago
ya you are right bro , people should know about it .
Why don't you write an article about it .
would love to read.
Reply 4 years ago
There are plenty of articles of this topic. No need to write another one. And I would probably be unable to do so anyways.
Reply 4 years ago
See this is the simple thing people don't wanna write but can talk about it anyways no issues .
there is huge way to give the people .
Reply 4 years ago
Yeah, I can talk about a lot of things. But to write a complete article... I'm just a twelfth grader, and do not know so much details, that would be necessary to write a complete article. I can talk to people though, help them in forums, and in other ways :). Sorry for grammar mistakes (if there is any). English is not my first language.
Reply 4 years ago
No issues brother , i am glad that you have interest in these keep learning one day you will write a wonderful article i know :)
No problem with grammar
btw whats your first language ?
Reply 4 years ago
I am from Lithuania. A small country in north-east europe. By the way, I looked into Li-ion protection circuits, and it looks like just a Zener diode instead of proper circuit might be a bad idea, because of voltage drops, etc. I myself do not quite understand all of the theory, however I found this article. http://electronicdesign.com/power/li-ion-battery-protection-circuit-draws-only-45-mua .
Reply 4 years ago
I was wrong about zener and i am sorry i did checked last night to find a solution i hope to get it soon.
Reply 4 years ago
In the article is shown a scheme of ultra low power li-ion undervolt protection. I'll try to build it sometime in the future. Maybe even create an instructable myself, if I manage to get the parts. Anyway, it would be interesting to try :)
Reply 4 years ago
ya do post me a link if you make ,
but in case of that if will increase the price .
Texas instrument boost coverter chips have that in them so its better to use that
Reply 4 years ago
I don't care that much about the price. I'm just morbidly curious. Not just about electronics.
Reply 4 years ago
Just looked it up. The price goes up quite a bit. LT1389 part costs 8.24€ and LT1495 costs 7.5€ in a local electronics store. That's pretty expensive for me. Maybe buying it from china would be cheaper...
Reply 4 years ago
said you na :P
Reply 4 years ago
Anyways, if I manage to get li-ion cells for free, total project cost would not be higher than cost of a proper battery pack. Also, this way, you get much more valuable information and experience :)
