Introduction: Pre-amp to Electret Mic!
This circuit is very easy to do!
and all parts of it are easy to find!
It is nice to put together with design of Rtty21https://www.instructables.com/id/Easy-AM-Transmitter/
"The easy transmitter am"
so you can talk on the radio or put somewhere
hear the conversations of others!
the parts you'll need for this project will be!
Q1 = 2N3904
R1 = 10k
R2 = 100k
R3 = 10k
C1 = 0.1μf or if you prefer 104 or 100n
C2 = 0.1μf or if you prefer 104 or 100n
MIC1 = a common electret microphone
to put it together to design rtty21
and just put the place marked as output to next stage
pin 4 for the 555 (ne555/lm555/7555/ka555)
and ready to feed it to the same source of another circuit!
My First Instructables
Yeah!!!! XD
with some debt and send a comment I will try to solve your problem!
33 Comments
Question 2 years ago
Can i use electrolytic capacitor?
6 years ago
Can i use 2n222 transistor for this circuit
Reply 3 years ago
Yes, I made with a 2n2222.
Reply 3 years ago
Most npn transistors will work.
3 years ago
I made it and instead of ceramic I used poly capacitors so it kinda didn't work then I added two 10 uf Electrolytic caps and it works like a charm. PS: I made it using BC 549 NPN and it works great. Also, it can be made by BC548. I am thinking of adding a BT preamp as well. I will keep you all posted. I made it because I use a BETA 58 (Replica of Shure beta 58A Mic) which is unable to work directly in the PC so I used an amp which used a power adapter of 12 v 500 mA but when I started recording it also gathered all unwanted noise signal. SO I made this amp and when I powered it up using the USB port of the system, Tada the noise is gone also the output is good too! so I am gonna put another transistor-based bass circuit in it so that I can reduce the vocal bass
4 years ago on Introduction
If you leave R1 out, it will work for a dynamic mic also
5 years ago
I made this circuit and was able to record some good audio connecting it to my systems's mic port, however there's this background noise that get's very prominent when I use a 9V source, with a 5V source it seemed somewhat eliminated.
How can I remove noise?
7 years ago
So I've been fiddling with the featured circuit more, to see if I could control the circuit characteristics more precisely. In particular, I wanted a circuit that "idles" with a V(ce) of 4.5V (since I'm powering it with a 9V battery) and I want 20 mA going across R3. I also want the output from the microphone to center on 4.5V. Using datasheets, Kirchoff's Laws, arithmetic, and a little trial and error, I've come up with these recommendations:
R1 - 18k (this could vary depending on your electret microphone)
R2 - 68k
R3 - 220 ohm
This makes for a satisfyingly sensitive microphone, and the electrical characteristics are about where I want them to be. I could probably rejigger this so that it runs on less current, but then I'd also have to figure out new R2 and R3 values (since, for what I understand to be best performance (which you supposedly get when Vce is half of Vcc), the current is going to determine R3 and therefore R2).
Reply 7 years ago
... you know, a smarter person than me wouldn't have spent so much time trying to work with data sheets and algebra and so forth. It's two simple steps:
1) Once you've decided on the current you want at Q, that tells you what R3 needs to be: it's Vcc divided by current, divided by 2 (because the intention is for the drop across R3 to be half of Vcc, and the other half will be across the transistor).
2) How to figure out what R2 needs to be to keep the transistor at half of Vcc? Just hook up a potentiometer, and adjust it until the voltage across the transistor is indeed half of Vcc. Then measure the resistance on the potentiometer.
When I just did this, I ended up with 72k; pretty close to what I got via much more complicated means earlier. Except using the potentiometer it took me less than five seconds.
Reply 7 years ago
For R2 and R3, values of 470k and 1k seem to work pretty well too.
7 years ago
Is the output considered "line level" ?
10 years ago on Introduction
This is sweet. I bought some super cheap electret mikes recently, and this is the third preamp I've tried to build. It's also the only one that works well. (I got a very nice progression from the first circuit as not working at all, to the second one working poorly and now this one working satisfactorily.
Reply 7 years ago
Keep improving your skills!
hey lucas can this preamp be used for normal mobile audio
Reply 7 years ago
What do you want to do with it?
8 years ago on Introduction
Awesome!
I attached this to my ipod amplifier, wired it to a speaker, and now peacefully listen to the outdoors from my basement.
Really good for your first instructable!
Reply 7 years ago
Thanks!
7 years ago on Introduction
can I connect the output to my pc ?? I mean when I talk can I hear my voice to the speaker connected to my pc coz I want to build it and record
how can i connect this to a speaker?
