Introduction: *Preliminary* SPI on the Pi: Communicating With a SPI 3-axis Accelerometer Using a Raspberry Pi
Step by step guide on how to setup Raspbian, and communicate with a SPI device using bcm2835 SPI library (NOT bit banged!)
This is still very preliminary... I need to add better pictures of physical hookup, and work through some of the awkward code.
Step 1: Starting With a Blank SD Card, Download Raspbian Image, and Install Onto SD Card
Visit http://www.raspberrypi.org/downloads for instructions on how to install Raspbian
I downloaded:
Raspbian image, and used
Win32DiskImager to install on SD card
There's also more information at http://elinux.org/RPi_Easy_SD_Card_Setup
I downloaded:
Step 2: Connect Raspberry Pi to TV/Monitor, and Run Through Initial Setup
(Internet connection not required yet)
Set timezone
enable SSH
Update
Then, Finish.
Terminal code:
reboot
Set timezone
enable SSH
Update
Then, Finish.
Terminal code:
reboot
Step 3: Optional: Operate Pi Headless
Excellent tutorial at
http://elinux.org/RPi_Remote_Access
I use Putty (Windows) or Terminal (Mac) to connect with SSH
Step 4: Recommended: Update OS
Terminal Code:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get update
Step 5: Optional: Setup IP Address E-mailer
I've set up my Pi to e-mail me it's IP address each time it boots. This makes my life easier when I need to remote login using SSH.
http://elinux.org/RPi_Email_IP_On_Boot_Debian
Step 6: Optional - Setup VNC
http://elinux.org/RPi_VNC_Server
I didn't go through the entire tutorial... just the following steps:
$ sudo apt-get install tightvncserver
$ tightvncserver
$ vncserver :1 -geometry 1200x800 -depth 24
And, I created a script to keep my typing to a minimum.
$ tightvncserver
Step 7: Install BCM2835 SPI Library
https://gist.github.com/3183536
Excellent documentation (and examples) at http://www.open.com.au/mikem/bcm2835
Terminal code:
cd;
// wget http://www.open.com.au/mikem/bcm2835/bcm2835-1.5.tar.gz; // My Pi can't figure out this URL - unable to resolve host name?
wget http://67.192.60.197/mikem/bcm2835/bcm2835-1.5.tar.gz
tar xvfz bcm2835-1.5.tar.gz;
cd bcm2835-1.5;
./configure;
make;
sudo make install
Terminal code:
cd;
cd bcm2835-1.5;
./configure;
make;
sudo make install
Step 8: Get ADXL362 SPI Example
Note: Code is still very basic... need to improve
get ADXL362_RaspPi from https://github.com/annem/ADXL362_RaspPi
(How to do this on Pi, using wget? I'm having trouble with this... "unable to resolve host address 'github.com'")
Step 9: Phyiscally Connect ADXL362 Breakout to Raspberry Pi GPIO
More details to come...
More info about ADXL362 (ultra low power 3-axis accelerometer) at analog.com/ADXL362
Connect 3v3, GND, SPI0 MOSI, SPI0 MISO, SPI0 SCLK, SPI0 CE0 N on Raspberry Pi to
VDDand VIO, GND (2), MOSI, MISO, SCLK, and CSB on ADXL362 Breakout board.
Step 10: Compile and Run ADXL362_RaspPi
terminal code:
gcc -o ADXL362_RaspPi -I ../bcm2835-1.5/src ../bcm2835.c ADXL_RaspPi.c
sudo ./ADXL362_RaspPi
Which I combines into a script called compileADXL362.
