Introduction: Premier Wonder Grinder Repair - Belts and Gears
Whether you're using the Premier to grind lentils or cocoa nibs to make chocolate, these machines definitely do wear down and need maintenance, especially if you notice black soot gathering around the base.
Bhavani is the main guy in the US who sells spare parts for these grinders, and it is highly recommend that you contact him rather than trying to find random parts for these grinders. He can be reached at bhavani@dtnj.com
The single most important thing to remember about working on any piece of electric equipment - UNPLUG THE MACHINE BEFORE DOING ANY WORK! I cannot stress this enough. Even with the machine unplugged, there is always still the risk of electric shock. Do not dissemble the grinder any further than these steps - there's really nothing else you can work on.
Step 1: Unscrew the Metal Shaft
Before doing anything else, unplug the Premier and hit the on/off switch to make sure there's no residual charge.
You may have to use quite a bit of force but these do unscrew.
Step 2: Pop Off the Plastic Ring Around the Drive Shaft
You can do this with finger pressure.
Step 3: Pop Out the Rubber Plugs From the Cover
Step 4: Unscrew the Four Screws That Connect the Top Blue Plastic Cover to the Motor
Step 5: Look at Your Gears
There are three things to work on - the large plastic gear, the smaller aluminum gear, and the belt that connects the aluminum gear to the motor.
The plastic gear pops off the base with significant force.
The aluminum gear is bolted to the base and can be unscrewed.
Step 6: Line Everything Up
When you're putting the plastic cover on, make sure the power button is resting on the spring which sits on the red power switch. The back of the cover has a slot for the power cord. This can be a bit tricky to line up.
Step 7: Screw Your Base Back in and Replace the Rubber Covers
Step 8: Document Your Maintenence
Especially when you have more than one grinder (we seem to get a new one every month or so these days), it's important to document which grinder is at which stage. We've noticed the serial numbers gradually going up with each new grinder we buy, so we write the serial number on the side so we can easily see which machine is which, and what maintenance was done.
Now that you've completed these steps, get back to grinding!
9 Comments
Question 9 months ago on Step 6
Hi,
My Prestige wonder grinder power button is not working(not holding ON continuously). Can I get a replacement part for it? If yes, could you guide me how to get this part ordered?
Thanks,
Nagendra
1 year ago
I have 1.5 liter premier wonder grinder. The motor stoped working and when I switch on it makes a whirring sound. How to fix the motor. The belt and the two gearts are in good working condition. Looking forward to your help. Thanks
2 years ago
Hi
My premier grinder top lock spring came out so I am unable to grind properly the flour, kindly explain how to fix ourself.
Tip 2 years ago
I want this pls help me
Question 3 years ago
Hi, my premier grinder overheats, shuts off and would restart when totally cool which is approx 1 hour, how can I fix it?
3 years ago
Hi, great instructable! Thanks for making it!
Does anyone know where to get a replacement switch? Mine stopped clicking into place - it will still turn on the machine, but, won't stay on unless I hold it down. I have taken it out and found that it's a Teknic PP95. Anyone know where to get a replacement? Thanks.
4 years ago
Thanks, worked great. I might add I got the parts from e-mailing the address you suggested and he directed me to https://www.melangers.com/collections/spare-parts/products/upgrade-kit
5 years ago
Thank you
7 years ago on Introduction
Thanks for the thorough Instructable! Hopefully we'll see many more from you in the future!
