Introduction: Premiere Pro Edit Dial Controller (Seek / Play / Pause) ($6 DIY)
I am selling a product that can be configurable with a web browser without coding.
Please take a look at below link!!
https://www.etsy.com/listing/985194207/parks-custom-dial-kit-customizable?ref=listings_manager_grid
Update!!!
New version is here!!
I’m really into making Youtube videos for Instructables. Sometimes it is hard to rewind the moment I wanted to pause. So, I thought it would be nice if I had a dial for it.
[ Instruction ]
Manual https://eunchan.me/PREMIERE-PRO-CONTROLLER-DIAL-DI...
Source Code https://github.com/happythingsmaker/PremiereProDi...
3D Printing File https://www.thingiverse.com/thing:2810760
[ About the maker ]
Youtube Channel https://www.youtube.com/EunchanPark
Step 1: Preparing Materials and Tools
[3d printing]
- First of all, you need to prepare some parts and 3d printing things. 3d parts are on the Thingiverse.
- https://www.thingiverse.com/thing:2810760
Step 2: Assemble the Encoder and the Arduino
The very first step is soldering.
This weird connection shows that I didn’t want to use any wires for soldering it at all.
I used digital output for giving ground and 5v.
It works well!
Step 3: Solder 5 Pins. It Is All!
Solder all five pins.
It is straightforward.
Step 4: Put the Circuit Board Into the Drum Frame.
There is a vertical hole on the side wall.
It is for USB terminal
Step 5: Fasten It
I uploaded a nut shape model on the Thingiverse just in case you don’t have a proper size of nuts.
(Using a M7 nut is better way.)
Step 6: Glue It (Optional)
If you want to fix it completely, glue it.
Step 7: Put Coins Into the Bottom Frame
Put 4 quarter into the bottom frame for making it heavy.
Step 8: Assemble Them Together
Step 9: Assemble the Dial Knob
Put the dial into the frame or you can use other knobs for it.
You can use other knobs (I prefer smaller one)
Step 10: Download the Source Code From Github
https://github.com/happythingsmaker/PremiereProDia...
just in case, here is code
<p>#include "Keyboard.h"</p><p>#define OUTPUT_B 15
#define OUTPUT_A A0
#define BUTTON A1
#define PIN_5V A2
#define PIN_GND A3</p><p>bool aState;
bool aLastState;
int lastButtonState = 0;</p><p>void setup() {</p><p> Keyboard.begin();</p><p> pinMode(OUTPUT_A, INPUT);
pinMode(OUTPUT_B, INPUT);
pinMode(BUTTON, INPUT_PULLUP);</p><p> pinMode(PIN_5V, OUTPUT);
pinMode(PIN_GND, OUTPUT);
digitalWrite(PIN_5V, HIGH);
digitalWrite(PIN_GND, LOW);</p><p> Serial.begin(9600);</p><p> aLastState = digitalRead(OUTPUT_A);
bool count = 0;
bool keyFlag = false;
long lastClickTime = 0;
long lastRotateTime = 0;</p><p>void loop() {</p><p> if (millis() - lastClickTime > 1000) {
aState = digitalRead(OUTPUT_A);
if (aState != aLastState) {
if (digitalRead(OUTPUT_B) != aState) {
Keyboard.press(KEY_LEFT_ARROW);
} else {
Keyboard.press(KEY_RIGHT_ARROW);
Keyboard.releaseAll();
aLastState = aState;
}</p><p> if (digitalRead(BUTTON) == LOW) {
if (lastButtonState == HIGH) {
Keyboard.print(" ");
lastClickTime = millis();
lastButtonState = LOW;
} else {
lastButtonState = HIGH;
}</p><p>}</p>
Step 11: Plug USB Cable
Meanwhile, plug usb cable into your arduino board and your PC.
if you didn’t install the arduino IDE, please install it.
Step 12: Select Leonardo
Select Arduino Leonardo in the Tool bar - Board - Arduino Leonardo
Step 13: Select Com Port
And Select the Communication Port which is in Tool - Port.
You can see the new port when you plug your Arduino to your pc
Step 14: Upload
Now, Hit the upload button
Step 15: Confirm "Done Uploading"
If you can see “Done uploading” text, it means done.
Step 16: Congratulations! DONE!
It has a click switch.
Everytime you click it, the arduino sends a space text.
So, you can make the premiere pro play and pause.
I think you guys have been suffered from this situation.
For example, I wanted to pause when the scene is changed.
But I cannot stop it immediately, So, I had no choice but to seek it by clicking here and there.
Now with this dial, I am able to seek it way better than ever.
![CHOOM [FINAL] Follower Robot Circuit Connection, Building Leader Robot](https://content.instructables.com/FE6/JBHP/KDU8TA57/FE6JBHPKDU8TA57.jpg?auto=webp&crop=1%3A1&frame=1&width=130)
![CHOOM [06] 21 Axis Humanoid (Follower) Robot](https://content.instructables.com/FTD/6LEJ/KDU8T65F/FTD6LEJKDU8T65F.jpg?auto=webp&crop=1%3A1&frame=1&width=130)
