Introduction: Printmaking: Drypoint
About: ideaLAB is the name of the Denver Public Library's free all-ages makerspaces. We have labs at 6 libraries around the city of Denver - Central, Hadley, Hampden, Montbello, Rodolfo "Corky" Gonzales, an…
Materials:
Plastic container or laminated cardboard*
Paper
Chalk or powdered makeup
*try drink cartons, milk jugs, produce containers
Tools:
Towel or old shirt
Scissors
Spoon
Bowl of water
Pushpin*
*Or screw, needle, nail
Step 1:
Cut out 2 squares of equal size from a smooth part of your carton. One square will be the printing plate. The second square will be the blanket.
Step 2:
Sketch a design onto one square. Use a pushpin to etch the design. This is your printing plate.
Step 3:
Rub chalk onto your etched design. The powder should fill the lines. Use your fingers to spread the chalk and wipe away any excess around the lines.
Step 4:
Put the printing plate face up on the towel.
Step 5:
Cut a piece of paper the same size as the printing plate. Dip your paper into a bowl of water. Let it soak for a few seconds. Remove the paper and shake off the excess water. The paper should be damp, but not dripping and soggy. This may take some trial and error.
Step 6:
Place the paper over the printing plate. Take the blanket square and place it over the paper.
Step 7:
Take the spoon and rub it back and forth across the blanket. Apply pressure while rubbing.
Step 8:
Peel off the blanket and paper to reveal the print! Rinse off and reuse the printing plate. Tip: To reduce wrinkling, lay the print between a towel and stack books or other heavy objects on top until it is dry.
Step 9: Experiment
Embellish your print!
Draw or color on your print. Print on patterned paper. Try different printing plate shapes.
