Introduction: Private Lock Box With Pin Code - Bluetooth Activated Lock
We all have some personal items we want to hide away from our pesky annoying siblings. Or maybe it's just me, but I've always felt like I want some privacy or at the very least have the peace of mind of knowing that someone's been snooping around.
I've devised a cheap and clever solution for all of us you simply want a little private box to protect our collectibles and keep things private! This is a bluetooth activated locked box with a pin code security system that will lock out for 5 minutes if the wrong password is entered, making it safe, secure, and private!
Step 1: Measure and Outline
Measure the size of the box that you want and mark it on a piece of foam board.
Step 2: Cut
Cut the outlines on the foam board. For the dollarama type of foam board I find it easiest to do a 75% score and then snap it, then cut the paper on the other side.
Step 3: Glue Box
Glue the sides of the box together except for the lid with a hot glue gun
Step 4: Glue Hinge
Glue the two hinges on the lid of the box with a hot glue gun. Make sure that the orientation is correct by rotating the hinges or following the image shown above. Use a generous amount of hot glue to make it stick well.
Step 5: Lock Mechanism
Glue two pieces of popsicle sticks perpendicular to each other, the glue it onto a servo horn to make the lock/hooking mechanism.
Then, glue this servo onto the front side of the box as shown in the picture.
Step 6: Lid Handle
Glue a handle like shown not he picture using popsicle sticks and a hot glue gun. Since the lid also acts as a double for the lock to hook onto, push the popsicle stick through to make the lid double sided.
* Make two small cuts on the top of the lid and insert the popsicle through.
* Then glue two perpendicular pieces onto the top and bottom pieces of the popsicle sticks sticking through the lid.
Step 7: Glue the Lid Hinge
Glue hinges of the Lid onto the box with hot glue.
That's it for the box!
Step 8: Wiring
* Connect the white pin of the servo motor to pin 9 on the Arduino.
* Connect the red pin of the servo motor to the 5V pin on the Arduino.
* Connect the black pin of the servo motor to the GND pin on the Arduino.
* Connect the barrel jack adaptor to the Arduino and glue the 9V battery onto the Lid.
Step 9: Code
Change the board name of your Arduino 101, I called mine Tech Martian. Then, upload the following code onto the Arduino.
#include <CurieBLE.h> #include <Servo.h>
BLEPeripheral blePeripheral; // BLE Peripheral Device (the board you're programming)
BLEService ledService("19B10000-E8F2-537E-4F6C-D104768A1214"); // BLE LED Service//set BLE characteristic
BLEUnsignedCharCharacteristic switchCharacteristic("19B10001-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);const int servoPin = 7; const int passCode = 22;
Servo servo1;
void setup()
//attach servo
servo1.attach(servoPin);
// set advertised local name and service UUID:
blePeripheral.setLocalName("Tech Martian");
blePeripheral.setAdvertisedServiceUuid(ledService.uuid());// add service and characteristic: blePeripheral.addAttribute(ledService); blePeripheral.addAttribute(switchCharacteristic);
// set the initial value for the characeristic:
switchCharacteristic.setValue(0);// begin advertising BLE service: blePeripheral.begin();
servo1.write (90); }
void loop()
// listen for BLE peripherals to connect:
BLECentral central = blePeripheral.central(); // if a central is connected to peripheral:
if (central)
// while the central is still connected to peripheral:
while (central.connected())
// if the remote device wrote to the characteristic,
// use the value to control the LED:
if (switchCharacteristic.written())
// any value other than 0, turn on the LED
if (switchCharacteristic.value() == passCode)
servo1.write (90);
//else lockout for 5 minutes
else
servo1.write (180);
delay(5*60*1000);
}Step 10: App
Download nRF Master Control. Connect to the your Arduino 101 board, the name of which you chose int he previous step.
* Connect to your Arduino 101 Board.
* Click the Upload Button
* Enter your password
Step 11: Enjoy!
Enjoy your privacy with your new private lock box!
