Introduction: Producing Electricity From Banana Stump: Stump Cell
This is a summer science activity that I did. This summer holiday I got a lightning idea. Actually this summer holiday I visited my native which is in Kerala, India, there are a lot of banana trees in my garden there, one day I came across a banana tree that my grandma was choping off, and suddenly I noticed a gelly substance inside it, I got curious and I came to know that it's citric acid!
At that point of time I had also came across the need of cheap energy by the people living in rural regions where there are acres of banana plantation but electricity supplies are not coming, and many rotten stumps are getting wasted, that I myself witnessed in front of me.
I got to know about this idea from Gopal Jee from Bihar, India, who discovered it, I thought to take this idea a bit far and I ended up with two crucial observations. I started learning more about the whole process to produce cheap renewable source of electricity through these banana stumps by incorporating the concept of Daniell cell here. This works on the principle of redox reactions. This can be revolutionary idea to help people living in rural regions at a affordable rate.
1) Banana stumps (more older, more preferred)
2) Electrodes (Zinc & Copper)
3) Wires
4) Voltmeter
Step 1: Understanding Redox Reactions
Now it's necessary to understand the two important components that make up redox reactions, that are 𝗼𝘅𝗶𝗱𝗮𝘁𝗶𝗼𝗻 𝗮𝗻𝗱 𝗿𝗲𝗱𝘂𝗰𝘁𝗶𝗼𝗻. Oxidation, is nothing but 𝗹𝗼𝘀𝘀 𝗼𝗳 𝗲𝗹𝗲𝗰𝘁𝗿𝗼𝗻 whereas reduction is 𝗴𝗮𝗶𝗻 𝗼𝗳 𝗲𝗹𝗲𝗰𝘁𝗿𝗼𝗻. So basically we can understand that those reactions that involve both oxidation and reduction simultaneously are known as redox reactions. These redox reactions have wide range of applications from burning of fuel used in rockets etc. to photochromatic lenses, as well as there are also many naturally occurring redox reactions like rusting of iron, so one such application was 𝗗𝗮𝗻𝗶𝗲𝗹𝗹 𝗰𝗲𝗹𝗹. So here I incorporated the Daniell cell concept to produce electricity from banana stumps.
I learnt more about redox reactions from various sources for this project, that included Wikipedia, YouTube , various other websites and I refered to grade 11 and 12 NCERT Chemistry textbook, and simultaneously I even prepared notes. The above images illustrated are notes that I prepared, there are also various examples of redox reactions illustrated above in my notes, you can refer them to get a clear idea!
There is one last concept that I want you to wrap your heads around that is 𝗢𝘅𝗶𝗱𝗮𝘁𝗶𝗼𝗻 𝗻𝘂𝗺𝗯𝗲𝗿, for now you just remember that oxidation number is nothing but charge that we denote on the upper right side of an element. So it's done you have understood the basics and what is needed now, about redox reactions.
Step 2: Understanding Daniell Cell
These two compartments in the Daniell cell are known as redox couples or half cells. I have drawn in the above image illustrating Daniell cell and even wrote half cell reactions separately. A salt bridge is used to link in order to maintain overall neutrality and to complete the circuit for the flow of current. Now you have even understood about the Daniell cell, hence accomplishing step 2 of the process.
Step 3: Incorporating Daniell Cell Into Banana Stumps
So I have incorporated the principle of Daniell cell into these banana stumps. First of all find a banana stump, I used the one which my grandma was discarding. Then get copper and zinc which act as electrode as Zinc readily loses electrons and copper gains it. Thus copper acts as cathode and Zinc acts as anode. Oxidation takes place at anode and reduction takes place at cathode. Now the only work we have to do is just pierce these electrodes into the banana stump, you can pierce it anywhere, it doesn't matter, now attach wires to the electrodes. There is no need of salt bridge as we are piercing it into the same banana stump. Connect electrodes wire into the voltmeter and test the flow. Finally it's done, you have a fully functional banana stump electrochemical cell with you. It's as simple as that. 3 Volts is enough to light a LED bulb for 3 hours. The stump produces electricity as long as there is citric acid inside the stump. Now you can use this electricity output to light the world around you!
Step 4: 1st Observation: Output Potential From Fresh Vs Old Banana Stump
𝗖𝗼𝗻𝗰𝗹𝘂𝘀𝗶𝗼𝗻: The output voltage increases with time as the stump gets older (rots) due to increase in the electrolyte present within them.
Then just for fun what I did was just took a few lemons (citric acid) and just squeezed into it, the output voltage suddenly increased and went upto 1.4 Volts in the old banana stump.
Step 5: 2nd Observation: Voltage Surge Reaction
𝗖𝗼𝗻𝗰𝗹𝘂𝘀𝗶𝗼𝗻 : Time till electrode pierced inside the stump is directly proportional to the voltage output.
Step 6: Conclusion
We must all help all the needy, across the globe in any way possible, by doing good deeds however small they may be. I encourage everyone to make use of their summer holidays in a beneficial manner and indulge into making new inventions or just indulge into any interested science activity. We all having the capacity and can invent and innovate new things to make the world a better place to live.....
Thankyou!
Pranav P D
