Program the Baofeng UV-5RA by and for New GMRS License Holder
Intro: Program the Baofeng UV-5RA by and for New GMRS License Holder
Using Chirp (Daily build) for setting up the Baofeng UV-5RA VHF/UHF tranceiver (hopefully)legally for GMRS license holders who wants to use the FRS, GMRS and MURS channels without getting in trouble with the FCC.
1. Buy USB cable for it (I found mine on ebay) and install using driver from Miklor or the CD.
2. Install Chirp (Daily build)
3. Download setup file (GMRS-MURS-FRS1-7-and-1-COP.img) from this site
4. Open setup-file in Chirp. Load stations from radio -and delete them. Copy and paste stations from setup file instead
5. Upload to radio.
6. Disconnect and you're done!
So why are these seemingly simple instructions even posted?
1. Because the FCC has determined that you now need to transmit more “narrow” on some channels than you used to -and that is “enforced” in this file
2. Because the UV-5RA is simply too powerful (even on the low transmission setting) for use on many FRS channels -and those are removed from this setup file.
3. Because researching this information took a lot of time and now you don't need to waste yours.
4. Because the last station is an example of how to block yourself from accidentally transmitting on a "listen only" channel. The channel used here is the local Police dispatch. Find your local station on http://www.radioreference.com.
Use these instructions at your own risk.
UPDATE/IMPORTANT: Don't buy this radio for use without a Technichian licens (or better). This radio is not approved for GMRS/FRS.
5. Upload to radio.
7 Comments
mtebert 10 years ago
Is this compatible with MAC?
realtalkradio80 8 months ago
its the baofeng uv5x . Basically uses uv5r case , however
Its totally gmrs legal . Everything is certified legal with the uv 5x for gmrs . The radio cannot be ham
Transmitted , and is solely built for gmrs .
just came out in last 2 yrs .
RaymondS19 8 years ago
Where do you get your information? It is approved with a fcc part 90 cert.
http://www.gordonwestradioschool.com/attachments/F...
Just have to make sure you don't have it set to 5 watts out. Choose the low pwr setting.
jameslee522 6 years ago
§95.129 Station equipment.
Every station in a GMRS system must use transmitters the FCC has certificated for use in the GMRS. Transmitters that have been certified for use in the GMRS may be found on the FCC Web site at https://apps.fcc.gov/oetcf/eas/reports/GenericSearch.cfm. All station equipment in a GMRS system must comply with the technical rules in part 95.
[80 FR 53752, Sept. 8, 2015]
iamjimmy86 10 years ago
FredRoyal 8 years ago
There is no rule against receiving on any of these frequencies, only against transmitting, with proper license. I hold both amateur and GMRS/FRS Licenses, the only restrictions I have to worry about is transmmition power levels.
CAMXposure 10 years ago
yes CHIRP is - MAC, PC, Linux
