Introduction: Programming an ATTiny13A Using Arduino & Servo Interpreter
So there I was, browsing eBay, looking for some cheap deals on Atmel chips when i came across a pair of ATTiny13 chips for £2.50. I just had to have them! After all, how hard can it be?
I needed a small chip to read servo signals from a hobby RC Receiver and control a laser output.
Once they arrived it dawned on me that I actually had no idea how to program these little chips. Dom and I spent hours trying various ways of ATTiny programming we found online with no luck. It was only until he left I sat down at my computer and found Tekstop's tutorial on 'Tiny programming that I had any success. With a couple of modifications to his files you will be up and programming these low price chips in no time!
Step 1: Connecting an ATTiny for Programming
Connect your ATTiny13A to your arduino following the diagram below
Arduino pin 12 - ATTiny pin 6
Arduino pin 11 - ATTiny pin 5
Ardunio pin 10 - ATTiny pin 1
Arduino +5v - ATTiny pin 8
Arduino GNd - ATTiny pin 4
Optional:
GND - negative side of LED
ATTiny pin 3 - resistor (250 ohm) - positive side of LED
ATTINY13A Datasheet: http://www.atmel.com/Images/doc8126.pdf
Arduino ISP info: http://arduino.cc/en/Tutorial/ArduinoISP
Step 2: Setting Up the IDE
- Open the arduino IDE and connect your Arduino
- Go to file > Examples > ArduinoISP
- Check you have the correct board & port selected (Tools > Board/Serial Port)
- Press the upload button
- Once complete, close the IDE
- Download and extract this file: https://github.com/tekstop/attiny/tree/Arduino1
- Copy the folder "attiny" from the extracted ZIP to the /hardware/ folder in your arduino IDE installation directory
- Open Hardware/attiny/boards.txt
- Scroll to the bottom of the file, this last few lines contains the data relevant to our chip
- Change "attiny13.build.f_cpu=9600000L" to "attiny13.build.f_cpu=1000000L"
- Open the Arduino IDE again
- Go to Tools>Board and select "ATtiny13 (internal 9.6 MHz clock)"
Step 3: Programming
- Open the IDE
- Click File>Examples>Basic>Blink
- Change line 11 from "pinMode(13, OUTPUT);" to "pinMode(4, OUTPUT);"
- Change line 15 from "digitalWrite(13, HIGH);" to "digitalWrite(4, HIGH);"
- Change line 17 from "digitalWrite(13, LOW);" to "digitalWrite(4, LOW);"
- Click File>Upload using programmer
Once this is complete (~5 seconds) your LED should start blinking with a 1 second interval
To address pins in the Arduino IDE you should use their PB number from the diagram below (EG Pin1 = PB1 etc..)
If all you wanted to do was learn to program your chip, then congratulations! You are done!
If you would like to build a RC Servo Interpreter then keep reading.
Step 4: Building the Servo Interpreter
Code is available in attached text file.
Connect the LED and resistor in exactly the same way as Step 1 states for testing purposes
If you use a relay it should be rated at 5V for the coil.
Connect the coil between pin 4 and GND
If using a relay you should also use a diode to protect the ATTiny from EMF by wiring it across the relay coil, negative(white band) side connected to pin 4.
Step 5: Testing 123
Hurricane Lasers Contest
Remote Control Challenge
38 Comments
4 years ago on Introduction
Thankyou
i solve the attiny13A delay promble follow your
Thanks
4 years ago
how can u use the instruction "if" in arduino ide ?? it is no supported
The following Arduino commands should be supported:
5 years ago
i made it
its so great and cheap for projects
careful this :
your arduino ISP have to be 1.0.x version
and you have to edit "wiring.c" file
5 years ago
Amkoshesh below is right - use the McUdude libraries to fix the problems with both the clock speed, and with the proper additinon on the ATTiny13A board to the Arduino 1.8.1 IDE.
Worked for me, using a SparkFun RedBoard as the programmer, with the same wiring layout as ooda55 details above.
https://github.com/MCUdude/MicroCore
5 years ago
http://forum.arduino.cc/index.php?topic=453093.0
My problem was solved
5 years ago
aaaallllllllloooooooooooooooooooooooooooooooooooooooooooooooooooo
even i had the same problem
Arduino: 1.8.1 (Windows 10), Board: "ATtiny13 (internal 9.6 MHz clock)"
The current selected board needs the core 'arduino:arduino' that is not installed.
Detecting libraries used...
recipe.preproc.macros pattern is missing
Error compiling for board ATtiny13 (internal 9.6 MHz clock).
Do you have a comment?
5 years ago
I just try " verify "
5 years ago
hi
Who can advise me about this problem
Error compiling for board ATtiny13 @ 9.6MHz (interne 9.6 MHz clock).
5 years ago
how to add libry for attiny 13A
5 years ago
can i make this with arfuino pro mini
5 years ago
5 years ago
Can i make this with arduino pro mini?
6 years ago
I had the same timing issue in the blink sketch, solved it by choosing from the Arduino IDE (v1.0.6) board selection submenu "Attiny13A standalone with 1.2MHz" clock.
6 years ago
I found out that the error "avrdude: please
define PAGEL and BS2 signals in the configuration file for part
ATtiny13" does not affect the programming. That went fine.
The delay in the blink-sketch is another issue: 1 second lasts like 5 seconds in the ATtiny13A.
6 years ago
Everything went very well, except programming the ATtiny13:
"avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny13"
what does that mean? thanks
7 years ago
Can the Attiny13(A) run at 8 MHz? I want to use the softwareserial library on it but it needs 8MHz (or other like 16MHz, correct me if I'm wrong.)
Reply 6 years ago on Introduction
Hi,
Thanks for the tut, it worked great on arduino 1.6.5 and a Nano Arduino.
I also want to use the softwareserial library on the ATtiny13A but i can't. do your serial communication work? Thanks.
Reply 6 years ago
Unless you use an external oscillator, the Attiny13 runs at unusual frequencies (like 128K, 1.2MHz, 2.4MHz, 4.8MHz and 9.6MHz)
The software serial library won't work without modification
6 years ago
That's beautiful mate!
I'm using that to control light and some sensors on my small RC airplanes, way cheaper and lighter than a arduino mini pro or a attiny85 :)
Cheers!
Informative
