Introduction: Programming an Animated Hourglass Display in Java
Introductory Java programming project that uses the basic skills I have been learning in my AP Computer Science A class recently! Skills/control structures used:
- Static methods
- For loops
- While loops
- Screen clearing command
- “Wait” x seconds function
If you are new to Java, learn with me as I build this project!
- Any sandbox/IDE capable of running Java (I use CodeHS because I am familiar with it, but websites like https://www.online-java.com are great too!)
- Only one file needed, but this is a stylistic choice
Step 1: Pseudo Code
Pseudocode is used to plan out the structure of what you want a program to look like. I include basic features like what I want to happen in a sequential order, different loop types with steps underneath them, declaration of variables, and where to put them (scope!)
TIPS:
- Your pseudocode doesn't have to be perfect. Get the general structure down (along with any questions and notes you have for your later self)
- This outline can turn into your documentation comments later!
Step 2: Create Your Hourglass Shape to Print
- Create the hourglass shape using forward and backwards slashes (\ /) for the walls,
- Use asterisks (*) to represent sand, only filling the top triangle completely
NOTE:
- It is important that you use exactly 30 asterisks for our program, since this is a 60 second timer, they will change at a rate of 1 * per 2 seconds!
Step 3: Animate Stars
- Create timer
- Establish the number of stars
- While loop that:
- Clears the screen
- Prints out updated timer
- Prints hourglass
- On every even time, removes one * from the top triangle and adds it to the bottom
- Updates timer and totalStar variables.
- Wait 1 second
Notes:
Use lines:
System.out.print("\033[H\033[2J");
System.out.flush();
to clear the screen, so the print statements don't stack on top of eachother 60 times.
Use line
Thread.sleep(1000);
to wait 1 second before moving on.
Step 4: Methods Called in the Above Step
- String removeStar(String line) --> Remove a * from the top of the hourglass
- String addStar(String line) --> Adds a * to the bottom of the hourglass
- boolean hasSpace(String line) --> checks for space inside the houglass before moving up/down a line
Step 5: Print Final Line
Created because the if statement breaks when time is 0, and the final frame still needs to be printed.
Step 6: Full Code to Play With!
public class HourglassFull {
public static void main(String[] args) throws InterruptedException {
// Top triangle
String t1 = " \\------------/";
String t2 = " \\**********/";
String t3 = " \\********/";
String t4 = " \\******/";
String t5 = " \\****/";
String t6 = " \\**/";
String t7 = " \\ |";
// Bottom triangle (empty at first!)
String b1 = " / \\";
String b2 = " / \\";
String b3 = " / \\";
String b4 = " / \\";
String b5 = " / \\";
String b6 = " /------------\\";
int totalStars = 30; //number o stars
int timer = 60; // countdown in seconds
while (timer > 0) {
// Clear the screen
System.out.flush();
// Show timer
System.out.println("Time left: " + timer + " seconds\n");
// Print hourglass
System.out.println(t1);
System.out.println(t2);
System.out.println(t3);
System.out.println(t4);
System.out.println(t5);
System.out.println(t6);
System.out.println(t7);
System.out.println(b1);
System.out.println(b2);
System.out.println(b3);
System.out.println(b4);
System.out.println(b5);
System.out.println(b6);
// Drop a star every 2 seconds
if (timer % 2 == 0 && totalStars > 0) {
// Remove a star from the top triangle (line by line)
if (t2.contains("*")) t2 = removeStar(t2);
else if (t3.contains("*")) t3 = removeStar(t3);
else if (t4.contains("*")) t4 = removeStar(t4);
else if (t5.contains("*")) t5 = removeStar(t5);
else if (t6.contains("*")) t6 = removeStar(t6);
// Add a star to the bottom triangle (bottom-up)
if (hasSpace(b5)) b5 = addStar(b5);
else if (hasSpace(b4)) b4 = addStar(b4);
else if (hasSpace(b3)) b3 = addStar(b3);
else if (hasSpace(b2)) b2 = addStar(b2);
else if (hasSpace(b1)) b1 = addStar(b1);
totalStars--;
timer--;
Thread.sleep(1000); // wait 1 second
// Final frame
//System.out.flush();
System.out.println("Time left: 0 seconds\n");
// Remove one star from the left star in a line
public static String removeStar(String line) {
return line.replaceFirst("\\*", " ");
// Addss one star in the first empty space from right to left
public static String addStar(String line) {
int left = line.indexOf('/');
int right = line.lastIndexOf('\\');
for (int i = right - 1; i > left; i--) {
if (line.charAt(i) == ' ') {
return line.substring(0, i) + "*" + line.substring(i + 1);
return line;
// Check if there is space to add a star
public static boolean hasSpace(String line) {
for (int i = left + 1; i < right; i++) {
if (line.charAt(i) == ' ') return true;
return false;
