Introduction: Project Motorcycle Footboards -
I wanted some footboards to go on the Dragstar, as the old one had them. They go, second hand, for £60 to £70 if you're lucky. So I went an alternate route with a pair I got off ebay very cheap :D
Step 1: Project Footboards - Plate Clean Up
Second part of the series - Deconstruction of the footboard, removal of the plate and its clean up.
Step 2: Project Footboards - Main Plate Preparation
Third part of the series - Cleaning up the footboard and preparing it for fitment.
Step 3: Project Footboards - Primary Fitting
Third part of the series - Removal of the original footpeg and Fitting the main plate for the first time.
Step 4: Project Footboards - Fixing the Bolts
Holes drilled, now to fit measure and fix the bolts.
Step 5: Project Footboards - Weather Proofing and Pad.
Weather proofing the wooden spacer block and cutting out the rubber pad.
Step 6: Project Footboards - Paint and Final Construction
Painting, fixing the two plates together and fitting the rubber pad.
Step 7: Project Footboards - Final Fitting
Bolting the finished footboard to the bike.
