Introduction: Project NANO Ball Machine
This is the second ball machine on this site. This is an even smaller machine than DEUX and hopefully more of you will build it. This machine has only ONE path and is easier still to build, though it still uses a lot of pieces. This also has a somewhat requested component, the Red Ball Drop.
So without further Pause, I present NANO!
Friendly and Critical comments are welcome, Spam will be deleted. unless it's religious war spam!
Pieces:
Gray Rods: 0
Red Rods:17
Yellow Rods: 98
Blue Rods: 152
White Rods: 81
Green Rods: 61
Blue 3D Rods: 56
Purple 3D Rods: 64
White 8-Slot Connectors: 43
Yellow 5-Slot Connectors: 30
Orange Tabbed 5-Slot Connectors: 0
Green 4-Slot Connectors: 1
Red 3-Slot Connectors: 58
Orange 2-Slot Connectors: 19
Gray 2-Slot Connectors: 6
Gray 1-Slot Connectors: 8
Tan/Brown/Orange Tabbed Connectors: 2
Wheels: 0
Motors: 1
Balls: 1 (or more)
Gears: 4 Red
Chain Links: 50
Total: 707 Pieces
Pieces:
Gray Rods: 0
Red Rods:17
Yellow Rods: 98
Blue Rods: 152
White Rods: 81
Green Rods: 61
Blue 3D Rods: 56
Purple 3D Rods: 64
Wheels: 0
Motors: 1
Balls: 1 (or more)
Gears: 4 Red
Chain Links: 50
Total: 707 Pieces
Step 1: The Rising Path
This is the medium upon which balls will travel upwards, propelled by the Claw Components.
Pieces:
Yellow Rods: 12
White Rods: 15
Yellow 5-Slot Connectors: 12
Red 3-Slot Connectors: 2
Total: 45 Pieces
Set this part aside, you will need it in the following steps.
Pieces:
Yellow Rods: 12
White Rods: 15
Total: 45 Pieces
Step 2: The Frame, Part 1: First Layer
This is the front part of the frame.
Pieces:
Yellow Rods: 11
Blue Rods: 20
White Rods: 6
Green Rods: 4
Blue 3D Connectors: 6
Purple 3D Connectors: 10
Red 3-Slot Connectors 2
Blue Bearings:4
Silver Bearings: 4
Gears: 2 Red
Total: 74 Pieces
Build this, then add on the Rising Path.
Pieces:
Yellow Rods: 11
Blue Rods: 20
White Rods: 6
Green Rods: 4
Blue Bearings:4
Silver Bearings: 4
Gears: 2 Red
Total: 74 Pieces
Step 3: The Frame, Part 2: Second Layer
This is the second layer of the Frame
Pieces:
Yellow Rods: 15
Blue Rods: 40
Green Rods: 8
Blue 3D Connectors: 19
Purple 3D Connectors: 19
White 8-Slot Connectors: 7
Orange 2-Slot Connectors: 4
Gray 2-Slot Connectors: 2
Total: 114
Build this, then attach it to Steps 1&2.
Pieces:
Yellow Rods: 15
Blue Rods: 40
Green Rods: 8
Total: 114
Step 4: The Frame, Part 3: Third Layer
This is the third part of the frame.
Pieces:
Yellow Rods: 17
Blue Rods: 32
Green Rods: 4
Blue 3D Connectors: 11
Purple 3D Connectors: 13
White 8-Slot Connectors: 3
Orange 2-Slot Connectors: 2
Total: 84
Build this and connect it to Parts 1, 2, & 3.
Pieces:
Yellow Rods: 17
Blue Rods: 32
Green Rods: 4
Total: 84
Step 5: The Frame, Part 4: Fourth Layer
The Fourth large piece of the frame.
Pieces:
Red Rods: 1
Yellow Rods: 17
Blue Rods: 35
Green Rods: 4
Blue 3D Connectors: 13
Red 3-Slot Connectors 1
Tan/Brown/Orange Tabbed Connectors: 1
Blue Bearings: 2
Silver Bearings: 1
Gears: 2 Red
Total: 97 Pieces
Build this, than attach it to the previous Steps.
Pieces:
Red Rods: 1
Yellow Rods: 17
Blue Rods: 35
Green Rods: 4
Blue Bearings: 2
Silver Bearings: 1
Gears: 2 Red
Total: 97 Pieces
Step 6: The Frame, Part 5: the Extender
This part extends the Frame by a small amount.
Pieces:
Yellow Rods: 3
Blue Rods: 5
White Rods: 3
Green Rods: 4
Purple 3D Connectors: 3
White 8-Slot Connectors: 1
Yellow 5-Slot Connectors: 2
Total: 24 Pieces
Build it and connect it to the Frame.
Pieces:
Yellow Rods: 3
Blue Rods: 5
White Rods: 3
Green Rods: 4
Total: 24 Pieces
Step 7: The Motor
Simply attach the motor.
Pieces:
Motors: 1
Total: 1 Piece
Pieces:
Motors: 1
Total: 1 Piece
Step 8: The Descent, Part 1: an Auxillary Attachment
A part that supports the Approach Path
Pieces:
Red Rods: 1
Yellow Rods: 1
Green Rods: 1
Total: 6 Pieces
Pieces:
Red Rods: 1
Yellow Rods: 1
Green Rods: 1
Total: 6 Pieces
Step 9: The Descent, Part 2: the Approach Path
This path approaches The Red Ball Drop.
Pieces:
Red Rods: 3
Blue Rods: 3
White Rods: 14
Green Rods: 6
Yellow 5-Slot Connectors: 4
Red 3-Slot Connectors: 12
Total: 46 Pieces
Build and attach to designated spots.
Pieces:
Red Rods: 3
Blue Rods: 3
White Rods: 14
Green Rods: 6
Total: 46 Pieces
Step 10: The Descent, Part 3: the Red Ball Drop Holder
This part supports the Red Ball Drop.
Pieces:
Red Rods: 2
Yellow Rods: 2
Total: 8 Pieces
Pieces:
Red Rods: 2
Yellow Rods: 2
Total: 8 Pieces
Step 11: The Descent, Part 4: the Red Ball Drop
Here is the Red Ball Drop, A segment that makes the ball descend, while keeping it perpendicular to the ground.
Pieces:
Red Rods: 4
Blue Rods: 7
White Rods: 1
Green Rods: 4
Blue 3D Connectors: 2
Purple 3D Connectors: 2
Red 3-Slot Connectors: 6
Gray 1-Slot Connectors: 6
Blue Bearings: 8
Silver Bearings: 4
Total: 48 Pieces
Pieces:
Red Rods: 4
Blue Rods: 7
White Rods: 1
Green Rods: 4
Blue Bearings: 8
Silver Bearings: 4
Total: 48 Pieces
Step 12: The Descent, Part 5: the Final Path I
This is the first part of a long path at the end of the descent.
Pieces:
Yellow Rods: 3
White Rods: 23
Green Rods: 14
White 8-Slot Connectors: 8
Red 3-Slot Connectors: 17
Total: 68
Pieces:
Yellow Rods: 3
White Rods: 23
Green Rods: 14
Total: 68
Step 13: The Descent, Part 6: the Auxillary Supporters I&II
These two support the first part of the Final Path.
Pieces;
Yellow Rods: 10
Total: 16 pieces
Pieces;
Yellow Rods: 10
Total: 16 pieces
Step 14: The Descent, Part 7: the Final Path II
This is an elongated part of the Final Path.
Pieces:
Red Rods: 6
White Rods: 6
Yellow 5-Slot Connectors: 5
Total: 21 Pieces
Pieces:
Red Rods: 6
White Rods: 6
Total: 21 Pieces
Step 15: The Descent, Part 8: the Auxillary Supporters III&IV
These parts hold up the end of the Final Path.
Pieces:
Yellow Rods: 1
Blue Rods: 9
White Rods: 1
Green Rods: 1
Total: 19 Pieces
Build these but set them aside for now.
Pieces:
Yellow Rods: 1
Blue Rods: 9
White Rods: 1
Green Rods: 1
Total: 19 Pieces
Step 16: The Descent, Part 9: the Final Path III
This is the end part of the Final Path.
Pieces::
Yellow Rods: 6
White Rods: 12
Green Rods: 9
White 8-Slot Connectors: 5
Red 3-Slot Connectors: 10
Total: 44 Pieces
Build this, then attach and attach the Auxiliary Supports III&IV
Pieces::
Yellow Rods: 6
White Rods: 12
Green Rods: 9
Total: 44 Pieces
Step 17: The Chain, Parts 1&2: the Chain and Claw
In this section you will make that final part, the Chain
First, make the Claw. Then, make the chain and attach both to steps 1-16
Pieces:
Blue Rods: 1
Green Rods: 2
Gray 2-Slot Connectors: 1
Gray 1-Slot Connectors: 2
Blue Bearings:1
Chain links: 50
Total: 60 Pieces
I only used one Claw, but you can use more if you want to use more than one ball.
Pieces:
Blue Rods: 1
Green Rods: 2
Blue Bearings:1
Chain links: 50
Total: 60 Pieces
Step 18: Wrap-Up
Congratulations! You Have Finished!
To turn on your NANO, turn the switch RIGHT.
Place a Ball on the Designated Stop shown Below,
and watch your machine Go.
Pieces:
Balls: 1 (or more)
Total: 1 (or more)
Pieces:
Balls: 1 (or more)
Total: 1 (or more)
Step 19: Troubleshooting
The NANO is an advanced piece of machinery,but it has its problems.
The most common problem is if the ball gets stuck - In this case just adjust the track.
Others:
P: My motor is not Running.
A: Either the batteries are dead or the motor is broken
If you have any other Questions, PM me and I will post the Solution
You For Reading,
-TM2koH
Trainman 2000 of Hyperborea
Others:
You For Reading,
-TM2koH
