Introduction: Project Uno - the Jamalam's First Attempt at a Ball Machine!
Hello everybody! This is my first attempt at a ball machine, I have built none ever before, and I used Darth trainman's instructables to help me, so some elements I give credit to Darth trainman for.
Pros
Have fun!
Nb. No piece count yet, because I am no good at them, can someone give me a piece count?Also, this ball machine can support at least 4 balls, i cannot test more because I don't have them :P
Pros
- Sort of piece ammount friendly
- 2 paths
- 2 towers
- Some elements!
- Some steps may be hard to follow, because I thought that if I broke it up too much, I couldn't put it back together again afterwards.
- May need editing for my low amounts of gears
Have fun!
Step 1: Piece Count - Courtesy of Knex Weasel!
Green Rod: 146
White Rod: 121
Blue Rod: 202
Yellow Rod: 142
Red Rod: 74
Gray Rod: 35
TOTAL RODS: 712
Y Connector: 5
Tan Connector: 7
Green/Black Hinge: 1
Blue Hinge: 1
Dark Gray Connector: 82
Light Gray Connector: 6
Orange Connector: 72
Red Connector: 81
Green Connector: 8
Yellow Connector: 110
White Connector: 33
Purple 3D Connector: 136
Blue 3D Connector: 69
TOTAL CONNECTORS: 611
Large Yellow Gear: 2
Red Gear: 1
Medium Yellow Gear: 1
Gray Gear: 2
Blue Spacer: 1
Silver Spacer: 10
Chain Links: 63
Ball: 4
TOTAL OTHERS: 84
GRAND TOTAL: 1407
White Rod: 121
Blue Rod: 202
Yellow Rod: 142
Red Rod: 74
Gray Rod: 35
TOTAL RODS: 712
Y Connector: 5
Tan Connector: 7
Blue Hinge: 1
Red Connector: 81
Green Connector: 8
White Connector: 33
Red Gear: 1
Gray Gear: 2
Blue Spacer: 1
Silver Spacer: 10
Chain Links: 63
Ball: 4
TOTAL OTHERS: 84
GRAND TOTAL: 1407
Step 2: Base
Try and build this, if you can't, then comment on the help step and I will postit in more detail.
Step 3: Tower 1
This is for tower 1, again, if you need help comment on the last step
Step 4: End of Both Tracks
Just build this
Step 5: The 1st Way
Build this as you go
Step 6: The 2nd Way
Step 7: Chain! :O
This is seriously the hardest part to build on the entire machine... I hope you don't believe me...
Step 8: Get Some Balls!
get at least 4 balls, i don't know how many it will support, but tell me.
Anyhow, add a motor to the red rod in the third picture, and it will work well. Send me a film!
Step 9: FAQ's
Ask questions and I will try to answer them!
