Introduction: Project1 LED
Inspiration for this project came from ring lights in the below video from 0:22-0:28
And below you can download the video of my result.
Step 1: Step 1: Identify the Positive Side of Your LED
The positive side will have a longer metal leg than the negative.
Step 2: Step 2: Place LED in the Breadboard
Place the LED as such in your breadboard with the negative leg in the blue ground lane.
Step 3: Step 3: Add Resistor
For this example I am placing a 100 ohm resistor in the same column as the LED. To calculate what resistor is needed for your LED use the formula found at http://www.ohmslawcalculator.com/led-resistor-calculator.
Step 4: Step 4: Connect Wire to Breadboard
Connect a wire to the column that the LED and resistor are in.
Step 5: Step 5: Insert Wire Into Pin
With your Arduino board unplugged insert the other end of the wire into pin 3 on your board.
*Note for this project I am using pins 3,5,6,9,10,11 as they are the pins on my Arduino Uno board that have PWM indicated by the ~ next to the number, check your board's specifications to select pins that also have PWM.
Step 6: Step 6: Repeat
Repeat steps 2-5, 5 more times
Step 7: Step 6: Ground
Place a wire in the blue ground lane.
Step 8: Step 8: Ground Part 2
Insert the ground wire into the ground pin on your board.
Step 9: Step 9: Upload Code
You can now plug your Arduino into your computer and upload your code to it, or copy the code below.
Project1 LED EffectDims up multiple LEDs at once, then dims all down, then chases multiple LEDs in sequence.
The circuit: - LEDs from pins 2 through 7 to ground
created 2018 by Steven Johnson */
int timer = 80; // The higher the number, the slower the timing.
void setup() { // use a for loop to initialize each pin as an output: for (int thisPin = 2; thisPin < 12; thisPin++) { pinMode(thisPin, OUTPUT); } }
void loop() { // iterate over the pins: for (int thisPin = 2; thisPin < 12; thisPin++) { // fade the LED on thisPin from off to brightest: for (int brightness = 0; brightness < 255; brightness++) { analogWrite(thisPin, brightness); } } // pause between LEDs: delay(1250);
// fade the LED on thisPin from brightest to off: for (int brightness = 255; brightness >= 0; brightness--) { analogWrite(3, brightness); analogWrite(5, brightness); analogWrite(6, brightness); analogWrite(9, brightness); analogWrite(10, brightness); analogWrite(11, brightness); delay(2); }
// loop from the lowest pin to the highest:
// turn the pin on: analogWrite(3, 255); delay(timer); // turn the pin off:
// turn the pin on: analogWrite(5, 255); analogWrite(3, 180); delay(timer); // turn the pin off:
// turn the pin on: analogWrite(6, 255); analogWrite(5, 180); analogWrite(3, 80); delay(timer); // turn the pin off:
// turn the pin on: analogWrite(9, 255); analogWrite(6, 180); analogWrite(5, 80); analogWrite(3, 0); delay(timer); // turn the pin off:
// turn the pin on: analogWrite(10, 255); analogWrite(9, 180); analogWrite(6, 80); analogWrite(5, 0); delay(timer); // turn the pin off:
// turn the pin on: analogWrite(11, 255); analogWrite(10, 180); analogWrite(9, 80); analogWrite(6, 0); delay(timer); // turn the pin off:
// turn the pin on: analogWrite(3, 255); analogWrite(11, 180); analogWrite(10, 80); analogWrite(9, 0); delay(timer); // turn the pin off:
// turn the pin on: analogWrite(5, 255); analogWrite(3, 180); analogWrite(11, 80); analogWrite(10, 0); delay(timer); // turn the pin off:
// turn the pin on: analogWrite(6, 255); analogWrite(5, 180); analogWrite(3, 80); analogWrite(11, 0); delay(timer); // turn the pin off:
// turn the pin on: analogWrite(11, 180); analogWrite(10, 80); analogWrite(9, 0); delay(timer); // turn the pin off:
// turn the pin on: analogWrite(11, 80); analogWrite(10, 0); delay(timer); // turn the pin off:
// turn the pin on: analogWrite(11, 0); delay(timer); // turn the pin off: }
