Introduction: Prop Zombie Gun From Crutch
This Instructable shows one way to make a prop gun out of a discarded crutch.
It has the essence of gun, without being too accurate and forgetting its crutchy heritage.
Various left over parts.
Mainly a crutch, a plumbing fitment, a piece of curtain rail and some spray paint.
Tools;
A hacksaw.
A drill.
A rivet gun.
A file.
A screwdriver.
Step 1: Step 1 - Materials
Here is the junk in the garden of a recently vacated neighbour; it has some broken crutches (perfect).
Also, here is my pile of metal bits from past projects.
Who on this planet can hold a crutch and not imagine it as a gun; not me.
So, this is a limited build using what I can find this morning, from some of this junk ; I will be making it up as I go along.
Step 2: Step 2 - Turn the Handle Round and Cut to Length.
To give it a better gun ergonomic I faced the handle the opposite way by drilling out the existing rivet, turning the handle, drilling a small hole and securing with a small self-tapping screw.
I cut down the crutch and the inner tube to a less crutchy size with a hacksaw.
Step 3: Step 3- Trigger, Trigger Guard and Muzzle Thing.
I hammered the muzzle block to the inner tube, (a perfect fit), but I did not like it and removed it later; I replaced it with the original rubber foot.
The trigger was a problem.
I tried this old bracket but I did not like it.
I decided to just go triggerless and just screwed on a trigger guard.
Step 4: Step 4- Magazine and Sights.
It needs a magazine; I cut a part of a curtain rail for the magazine and used two old brackets as the housing.
I simply used the holes in the brackets to rivet the magazine in place.
What ever this plumbing item was, it is now a telescopic sight; I drilled a hole through the whole assembly and bolted it all together.
The old jubilee clip was used as a spacer and hopefully looks like a sight adjuster.
Step 5: Step 5 - Telescopic Butt
I drilled the rivet off the arm-cuff and replaced it with part of a metal bracket, by drilling and bolting on.
Step 6: Step 6- Spraying
I had just enough olive drab and black to cover it.
But the lack of trigger is vexing me . . . so a solution must be found.
Step 7: Finished.
I found this fastener.
I interrupted filming.
I only had to remove 1 screw to install it.
The End.
