Introduction: Propagating Plants by Air Layering
Air layering is a propagation method for woody plants that allows you to root branches while still attached to the parent plant. It is useful for plants that are hard to propagate by cuttings or if you want your new plant to have a larger size than could be accomplished by taking cuttings.
I've used this method successfully for
- Weeping Fig (Ficus benjamina)
- Long-Leaf Fig (Ficus binnendijkii)
- India Rubber Tree (Ficus elastica)
- Fiddle-Leaf Fig (Ficus lyrata)
- Umbrella Tree (Schefflera arboricola)
- Elephant Yucca (Yucca elephantipes)
- Cornstalk Dracaena (Dracaena fragrans - pictured below)
It should work for most, if not all, woody houseplants, and even for outdoor plants.
Step 1: Tools and Materials
- the plant you want to propagate
- a sharp knife
- Sphagnum moss (should be available at garden centres)
- a piece of (preferably transparent) plastic foil (an old plastic bag will do fine) (about 30x30 cm)
- string
- a piece of thin, hard plastic (I used a piece of a plant tag, a piece of a plastic bottle or yoghurt tub or something similar would work just as well. Basically, you just need something thin that will not decompose if it's damp for a couple of weeks). It should be just a bit longer than the width of the branch you want to root.
- scissors for cutting string and plastic foil
- water
- a bowl to soak the moss in
A couple of weeks later, you will also need:
- a flower pot
- potting mix
- maybe a stake and more string.
Step 2: Preparations
- soak the moss, then squeeze out the excess water. You need enough to make a fist-sized ball if you lightly press it together.
- cut the plastic foil/bag and hard plastic to the proper sizes (about 30x30 cm and slightly larger than the width of your branch, respectively).
- cut two pieces of string, long enough that you can wrap it around your branch a couple of times and easily tie it, about 20-25 cm)
- choose the branch you want to root, and the place where you will cut it (preferably just under a node - that's the place where a leaf is/was attached). If necessary, remove some leaves - you'll need about 10-20 cm of leaf-less branch.
Step 3: Cut the Branch
Make an upwards-slanted cut about halfway to two-thirds through the branch. Take care not to cut so far that the branch breaks.
The way I've learned it, you support the branch with your thumb, then pull the knife towards it with your fingers (as seen in the picture). Place your thumb so that the knife blade would, if you cut all the way through, move past it rather than directly towards it - that way, if you accidentally cut too far, you minimize the danger of cutting yourself.
Step 4: Insert the Plastic
Take the small piece of plastic and insert it into the cut. This will keep the cut from closing up again, encouraging the plant to grow roots instead.
Step 5: Wrap With Moss
Take your damp moss and wrap it around the cut. Like I said in step 2, it should make a fist-sized ball, all around the cut. Don't press it together too tightly, it should feel... how to describe it? ... sponge-like.
Given time, the plant - encouraged by the moisture and the cut - will grow roots into this moss.
Step 6: Wrap With Plastic Foil
Holding the moss in place with one hand, wrap the plastic foil around it. It might be good to have a helper at this stage - this is a bit tricky the first couple of times.
Tie the plastic tightly below and above the ball of moss.
If necessary, tie the branch to a stake to support it (being halfway to two-thirds cut, it may be in danger of breaking).
Step 7: Cut the Rooted Branch
After a couple of weeks or months (depending on the plant and its growing conditions), you should see roots growing through the moss. This is why I prefer transparent plastic to wrap around the moss - makes it easier to check the progress.
If it takes longer than a few weeks, you might want to open the plastic foil, and make sure the moss is still damp. Otherwise, just leave it alone and wait.
When you can see well-develloped roots, cut the branch below the moss ball.
Step 8: Potting Up
Remove the plastic wrap, but leave the moss ball alone so as not to damage the roots. Pot the new plant up using good-quality potting mix and a smallish pot - I prefer not to go over 15 cm diameter for that first pot, smaller than that if the plant is little enough to stay upright in a smaller pot.
The reason behind this is that if the pot is a lot bigger than the still-small rootball, the soil will stay wet for a long time, because the plant can not yet take up so much water, and this can cause the roots to rot.
So you should also take care with watering during the first few weeks, keeping the soil moist enough that the plant doesn't wilt, but never, ever truly wet.
Garden Contest
30 Comments
2 years ago on Step 8
Clearest description of the process I have found yet. Nice work!
3 years ago on Step 3
I noticed the Missouri Botanical Garden has pages describing two methods, for air-layering for propagating indoor plants.
A method for air-layering monocot plants:
https://www.missouribotanicalgarden.org/gardens-ga...
A method for air-layering dicot plants:
As far as I can tell, the only difference in these two methods, is the way the branch is cut.
For monocot plants, the cut is a single deep slit, with some inert foreign object, like plastic card or wood toothpick, stuck in the cut, to prevent the cut branch from knitting itself back together.
For dicot plants, the cut is shallow, and ring-shaped, essentially removing a ring-shaped layer of bark.
You might have noticed some commenters mentioning this method, a cut that removes a ring-shaped layer of bark, with regard to Step 3, including user AmberB120 (+2 years ago) and user dwoloz (+10 years ago).
I don't know if we consider the Missouri Botanical Garden as an authoritative source for this sort of thing, but to me it looks like what they are saying is: the deep slit kind of cut, is best for monocot plants, and the cut that removes a ring-shaped layer of bark, is best for dicot plants.
Question 3 years ago on Step 8
once you separate the cutting from the parent plant, how do you should be step 9dress the "wound"? Seems like that should be step #9.
13 years ago on Introduction
i love the idea that someone is out there experimenting with other methods of propagation i have learned about using honey recently and i really enjoy anything i can do without having to spend money or drive all the way to town to spend money and gas THANKS ALOT and KEEP POSTING
Reply 3 years ago
How do you use Honey?
12 years ago on Step 8
Thanks for that going to try it on a Japanese Maple that has had failed cuttings from.
Reply 3 years ago
Did you have any luck? I would like to try this also
My. Dracaena Plant is hitting the ceiling I need to know how large of a section to root and if the remaining stump will put out a new top; I’d like to do about half of the tallest section which would be approximately 3 feet
TIA
7 years ago
I wonder if adding a little rooting liquid to the water prior to soaking, will increase success here. Anyone try this? Especially for outdoor tougher to root plant types.
Reply 4 years ago
All the instructions I've seen say you should apply powdered hormone to the 1 inch section where you've removed the bark and the green layer just underneath.
The moss and plastic are then applied after the hormone. If you are doing it to outside plants that will be in the sun you should put foil over the plastic so the moss doesn't dry out.
Reply 7 years ago
Hey. I'm actually doing a project on Air-Layering and yes, by using rooting liquid/powder it increases success. I'm not sure about the outdoor plants tho. I suppose it should be able to work as well.
Tip 4 years ago on Step 3
you can also use the knife and strip the outer layer away about a 1 inch section all the way around. I'm not sure if it works on all plants but in Ficus elastica it does
5 years ago
I have a Parlor Palm that I've had since high school in the 70's. Yes, it's that old! It's a little over 8' tall, and recently the top portion (about 3' or so) just fell over. I picked it right back up and supported it with some bonsai wire and it's been holding, but I don't think this will be permanent. Obviously after caring for this plant for nearly 45 years I would like to keep it. What do you think the chances are of performing air layering on this old boy? I have, over the years, cut 6-8" off the roots, buried it deeper in the soil and new roots do form along the newly buried stalk.
Reply 5 years ago
I've never really worked with palm trees. I know their trunk has a different structure than other trees, so I'm not sure air layering would work. I'm leaning towards "probably not".
If a parlor palm is what I think it is (English is not my native language, and vernacular names are always... imprecise), I think your best hope is waiting for suckers to grow at the base.
5 years ago
Let's say I have a 6 foot long branch that's growing laterally. Could I air propagate, in 2 foot intervals along this branch, to get three root balls and three new offspring?
Reply 5 years ago
I would to it in stages - root and cut off one part after the next. It will take three times as long, of course, but since you have to cut the branch partway, I would worry about it breaking, especially at the cut closest to the trunk, since there'd be a lot of weight on it.
6 years ago
Hai should we watering in air layering part or just we leave it. Then it will be grow own
6 years ago
Hello, daft question maybe, but do you remove the plastic insert before applying the moss and seal?
Reply 6 years ago
No, you leave it in, to keep the cut from healing up again. (Since the cut is what "motivates" the plant to grow roots.)
Reply 6 years ago
I see. Thanks very much for the tips!
