Introduction: Multicolored Blinking LED Light Sculpture
This Instructable uses an Ikea Candlestick and multicolored LED's projecting into large marbles. All of it is fixed on a hand-made pine base. This is how I made it.
Step 1: Materials & Tools
- Multicolored LEDs from Amazon Amazon LED's
- 2X AA Battery Holder from Amazon Battery Holder
- 2 AA Batteries
- Ikea Candle holder
- 1 to 1.25 inch marbles
- 3/4 inch pine 8X8 inches
- Wire
- Shrink tubing
- Switch
- Metal Screws to hold candle to base
- Spray Lacquer
- Mineral spirits
- Rubber Feet
- Hot Glue
- 5-minute Epoxy
Tools
- Drill or Drill press with various size bits and forstner bits
- Driver
- Soldering Iron
- Heat gun for shrink tubing
- Sanders - table and random orbit
- Router with roundover bit
- jigsaw or bandsaw
- Hot Glue gun
Step 2: Prepare the Candle Holder
- remove the thin caps by drilling thru and use a driver to pry the cap out
- drill a hole at the base of each to pass a thin two stranded wire thru
- drill a hole to attach the candle holder to the base
- pass wire thru the three sections and leave 6 inches below for attachments
Step 3: Make the Base
- Cut an 8 by 8 square
- mark the center
- Draw an 8 inch circle
- Mark the position of the candle holder
- Transfer the position of the holes and drill thru the base
- Turn the base over and use forstner bits to recess compartments for the battery holder, the switch and to make channels for the wire.
- Use a jigsaw or bandsaw to cut the circle out
- Clean the edges with a sander
- Use a roundover bit on a router for the top
- Sand to 120 or 220 grit
- Use a tack cloth to remove sawdust
- Use mineral spirits to fully remove sawdust and let dry
- Apply 6-8 coats of spray lacquer, allowing 1/2 hour between coats to dry
Step 4: Wiring It Up/Finishing
- Insert the on/off switch
- Solder the LED's to the wires using shrink tubing
- connect the LED's in parallel using the switch
- Use Shrink Tubing on all connections
- Hot glue the LED to the bottom of the marbles
- Use epoxy to attach the marbles securely to the candle stick holders
- Put self-adhesive rubber feet on the bottom to protect furniture
