Introduction: Pull Apart a HDD
This is just a little trip through pulling apart a HDD. Have a look inside, and score a few goodies!
Step 1: Tools
1. Good screw driver set
2. A HDD
Step 2: Remove the Screws
Find the funny looking screw bit in your kit hook it up and remove the screws in the top casing.
I'm using a T8 screw bit
Don't forget the hidden one under the paper/plastic coating
Step 3: Taking Off the Lid
Now just go ahead and rip off the top.
It's a little tough, I tried with my fingers but ended up putting a flat head screw driver in it and prying it open
Step 4: Remove the Magnets
Now, just get that flat head screwdriver under the magnet and rip it out.
Now before you can rip the other magnet out there are a couple of things you have to do.
1. Remove more T8 screws
2. Remove the swing arm
Step 5: Removing the Disk
Did you say more T8 screws... Yup
Remove the three screws in the top of the spindle.
I found the spindle moving so shoving some pliers in to grip made it easier
Tip the HDD upside down and shake it till the disk falls out.
There one shiny disk
Step 6: Removing the Spindle
Unfortunately because of its casing, this HDD doesn't allow us to remove its spindle.
However I do have spindles from other HDD's to show you!
Step 7: Remove the Board
Only 5 T8 screws stand between you and a disassembled HDD.
Remove these and pile your loot!
Step 8: Loot!
After pulling all the bits and bobs apart here is what we're left with.
Hope this helps you on your way!
Thanks for viewing!
