Introduction: Pumpkin Drink Tap
This is an inexpensive drink tap for a pumpkin, great for Halloween or other fall parties.
Step 1: Pieces
This tap will require the following:
- 1/2" 90 degree elbow
- 2 x 1/2 pvc pipe 1" long
- 1/2 " pvc valve ( I picked this style because it was slightly less expensive)
- 1/2" screw
- 1/2" screw
Step 2: Clean the Pumpkin
Cut off the top of the pumpkin as if you are going to carve it and clean it out really well. make sure to rinse out any excess bits to prevent them from clogging the spout.
Step 3: Step 1
Use a piece of 1/2" round PVC pipe and a hammer to drive a hole horizontally near the base of the pumpkin. Make sure to get into the inside cavity of the pumpkin.
Step 4: Tap It
Push hard on the PVC screw and twist it into the hole in the pumpkin. I tried to just use a piece of pipe pushing in the hole, but it leaked and was not very secure. Next push together the rest of the pieces.
note: you may choose to glue all the pieces together to ensure no leaking
Step 5: Done
Fill the pumpkin with your prefered brew and call all of your friends. The recipe we used is below, it was great and guests liked it.
Brew:
2 parts apple cider
2 parts ginger ale
1 part spiced rum
Brew:
2 parts apple cider
2 parts ginger ale
1 part spiced rum
