Introduction: Pumpkin LED Light
What you'll be needing:
- Pencil
- Tissue box
- Scissors
- Markers/Pencil crayons/ Acrylic Paint
- Ruler ( I will be using an measuring tape)
- Led Lights
- Pencil
- Tissue box
- Scissors
- Ruler ( I will be using an measuring tape)Led Lights
Step 1: Starting Off
Cut off the part of the tissue box which has a hole. Its should look like the second picture. Now, cut of on piece. (cut of the wider piece).
Step 2: Measuring & Cutting #1
Once you have done so, Measure out 1 11x11cm square, then measure out 1 10x10cm square. Once you have done so, fold 1cm on the side so it is facing up, It should look like the picture if done correctly. Then, cut another piece of the tissue box ( the last wide one).
Step 3: Measuring & Cutting #2
Once you have the other wide tissue box piece, You will have to do the same thing. Measure 1 11x11cm square, and measure 1 10x10cm square. Then cut it out.
Step 4: Gluing It Together
Once you have the 4 pieces have the 11x11 square on the bottom, then put hot glue on the folded sides, then put the 10x10 piece on the side where the glue is, once you have done that on each side glue the 11x11cm piece on the top. Now, get your Acrylic paint.
Step 5: Painting
Now that you have glued some parts together, You will need to pant it. Make sure the outside is orange and the inside is black.
Step 6: Face & Top
After you have finished painting, you'll need a face and a top for the pumpkin. So, you will need to measure out how you want everything to be. I made a scary face on mine! You can make whatever face you want.
Step 7: Gluing the Last Bits Together
After you have carved the pieces, You'll need to glue everything together.
Step 8: LAST STEP!!
Welcome to the last step! The last thing you need to do is put your light in the pumpkin, and you done!
