Introduction: Push Rollbot
This is my push and roll robot made from a single servo, a tilt sensor (VTI SCA610 Inclinometer accelerometer) and an Arduino Uno. The second half of the video gives some details on how it works.
Here is Arduino program:
// Push rolling robot with single servo, tilt-sensor and Arduino Uno
// by Jim Demello 1/12/2015
#include
Servo myservo2;
int Forward = 1;
int rollCntr = 0;
int val; // variable to read the value from the analog pin
int gyroPin = 5; //tiltmeter VTI SCA610 inclinometer chip (gyro?)
int gyroVal = 0;
void setup()
myservo2.attach(9); // attach servo pin 9
myservo2.writeMicroseconds(1500); // center servo
delay(15);
Serial.begin(9600);
Serial.println("Program start...");
void loop()
val=90; //servo centered at 90 degrees
gyroVal = analogRead(gyroPin);
gyroVal = map(gyroVal, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
delay(10);
if(rollCntr > 4) { if (Forward) {Forward = 0;} // reverse direction
else Forward = 1;
rollCntr = 0;}
if(Forward && (gyroVal > (val - 5) and gyroVal < (val +25 )))
{ myservo2.write(40); delay(500); myservo2.write(90); // go forward
rollCntr = rollCntr + 1;
if (!Forward && (gyroVal > (val - 25) and gyroVal < (val + 5 )))
{ myservo2.write(150); delay(500); myservo2.write(90); // go reverse
Serial.print(" level @ : ");Serial.print(val);Serial.print(" angle: ");Serial.print(gyroVal);
Serial.print(" Forward: ");Serial.println(rollCntr);
delay(40); //
