Introduction: Push Up Counter Using Arduino
I am going to show you how to make a DIY push up counter with arduino and the ultrasonic sensor
1. Arduino Uno
2. HC-SR04 Ultrasonic Module: https://amzn.to/2zLomJU
3. 4 Digital Display TM1637: https://amzn.to/30Qg2DK
4. Passive Buzzer: https://amzn.to/2BeYzu3
5. Switch: https://amzn.to/3hKNL7N
Step 1: Wiring
Wiring is pretty straightforward, just follow the schematics given above and you will be fine
Step 2: Coding
First of all we need to install the library
Open "Sketch" then go to "Library Manager" in the Arduino development software, then search for TM1637, and then install TM1637.
Enter the code given below
#include <TM1637Display.h>
//HC-SR04
//Youtube link: https://youtu.be/u9JauTRP_cc
#define echoPin 2
#define trigPin 3
#define resetPin 4
// 4-digital display pins
#define CLK 8
#define DIO 9
TM1637Display display(CLK, DIO);
float duration; //micro second
float cm;
long numDisplay=100;
boolean trigUp = false;
boolean trigDown = false;
float counterPushUp=0;
int buzzer=7;// Passive buzzer pin
void setup() {
pinMode(buzzer,OUTPUT);
Serial.begin(9600);
pinMode(trigPin,OUTPUT);
pinMode(echoPin,INPUT);
pinMode(resetPin,INPUT_PULLUP);
display.setBrightness(4);
display.clear();
delay(500);
display.showNumberDecEx(numDisplay, false, true, 4, 0);
void loop() {
//reset by switch
if(digitalRead(resetPin)==0){
trigUp=false;
trigDown=false;
counterPushUp=0;
digitalWrite(trigPin,LOW);
delayMicroseconds(2);
digitalWrite(trigPin,HIGH);
delayMicroseconds(100);
// receive, convert time (us) to cm
duration = pulseIn(echoPin,HIGH);
cm = duration * 0.034/2.;
if (cm>15 && cm<=30){
trigUp = true;
else if (cm < 10){
trigDown = true;
else if(cm >30) {
if (trigUp==true && trigDown==true){
counterPushUp=counterPushUp+0.5;
trigUp=false;
delay(500);
tone(7,800,40);//buzzer pin 7 frequency 800 duration 500
trigDown=false;
display.showNumberDecEx(counterPushUp, false, true, 4, 0);
Step 3: Testing
Connect the Arduino to the laptop, hit upload and do them push ups!!!
Keep tinkering!
