Introduction: Put Reason Under Foot
The first time I made a skatebord,after enduring the impulse to hit the table,I made my most satisfied shatebord.
Step 1:
select the cylinder roller from the tool
and rotate it 90 degrees. I'm going to stretch it a little bit.
Step 2:
lift the ring to half the height of the
cylinder tube roller and combine it with the cylinder tube roller.
Step 3:
locate the wheel in the toolbar, shrink it
and rotate it 90 degrees to make it stand up, then connect it to the cylinder roller. And the wheels were made.
Step 4:
Step 5:
pull a cuboid onto the working surface,
change its height to 3mm, then drag the Tangent Ogive to the working surface, make it high and shorten as one of the parts of the bearing, and combine with the cylinder roller.
Step 6:
pull the complex shape of the trapezoid, make it
smaller, then raise it to the height of the p-ring, and put it into the p-ring, make the trapezoid design transparent, and change the above elements into one, making it appear a trapezoid blank. Drag two hi-res Paraboloif and adjust the height so that they are exactly the height of the p-ring. Insert them into it and make it transparent. Put the above parts together.
Step 7:
drag the gear ring and 1so metric thread to the
working platform, the gear ring is on the outside, raise them to the same height, connect them together. Put them in the trapezoid space. Put them together.So the bearing is done.
Step 8: Making Skateboard Surfaces
drag the
cuboid to the working plane, set the height to 3mm, drag the Angle tube to the working plane, turn the concave surface towards the cuboid, and rotate it 90 degrees to make it lie flat on the working plane. Adjust its size to make it equal to the cuboid, drag another cuboid to the working plane, make the cuboid and the Angle tube overlap, make the cuboid transparent.
Step 9:
lift the cuboid to a certain height to fit
the bearing.Assemble the skateboardCombine the two parts into one.
