Introduction: Put Up Your Vinyl Wall Art - Wall Stickers - Decal Mural
Removable wall stickers are great for any surface. Perfect for rentals and apartments, home, the office or your fancy pants yacht. Put it on your laptop, put it on a window, put it on your face... do some DIY design. When you feel like changing, just peel it off and smack up another.
Tacky Smack provides these products, sometimes called wall tattoos, wall decals, vinyl surface art, window clings and window stickers, but call them what you will... they are much nicer than posters, cooler than canvas, cheaper and easier than paint. Removable stickers don't have any messy adhesive. Home decor in a new direction.
From Tacky Smack
This product is: Hanging Gardens - by Jeff Larson
For a video, check this out the Tacky Smack help page...
http://tackysmack.com/help
Step 1: Look Where You're Going!
Clean, dry and smooth should describe your surface. If you've painted within the last 3 weeks make sure your paint is completely set. We know you're real excited to get these suckers on the wall - but put on the brakes if you can stand it.
Also, cut the individual images out and tape them up on the wall so you know exactly where you want them to go. Smacking prematurely is not recommended!
Step 2: Prep Your Design for Installation
This step helps the vinyl stick to the clear transfer tape so you can peel off the white backing paper.
Put the design on a table, graphic side up. Use the squeegee we gave you. (If you lost our precious gift you still aren't totally out of luck. You can use a credit card, one of those hotel room keys that you're not sure you are obligated to give back, or a rubber spatula. Don't use a metal spatula.) Press and firmly drag the squeegee back and forth across the design. Now flip it over and do the same thing on the other side.
Step 3: Peel Off the White Backing Paper
With the design face down, start at a corner and peel the white backing paper off the clear transfer tape, rolling it back as you go.
Some of the more complicated graphics may be stubborn, and the vinyl doesn't release as easily from the white backing paper to the clear transfer tape. When this happens, don't freak out! Just stop peeling and roll back a little, and try again. You may need to crease the white backing paper where the vinyl isn't releasing in order to coax the vinyl off. See our online help pages for images. The key to success is to go slow.
Step 4: Time to Smack Up Your Tack!
Step 5: Remove the Clear Transfer Tape
Step 6: Sit Back and Enjoy Your New Tacky Smack!
Get your own at Tacky Smack
Please send us a photo!
