Introduction: Pyramid Marble Run
Have fun making this simple ‘Pyramid Marble Run’
- Cardboard
- Hot glue gun
- Scissors
- Pen
- Sticky tape
- Ruler
Step 1: Cutting the Cardboard
Cut 5 triangles from the cardboard
Cut 4 equilateral (all sides the same) triangles I cut mine 18cm
Cut the fifth triangle 1 cm larger (used later for the marble ramps)
Step 2: Joining the Triangles
Take the four small triangles and place them together with all the corners at the top
As shown In the picture
Step 3: Tape Them Together
Take some tape and tape the triangles together
Step 4: Making the Pyramid
Fold the right side triangle down and then fold the left triangle down
The tape on the right triangle will join the two triangles together
Open it out to make the pyramid
Then take some tape and tape the top to secure the pyramid
Step 5: Making the Base
Take a sheet of cardboard and put your pyramid on it
Then take a pen and trace around the pyramid
Once you have finished tracing all sides take a pair of scissors and cut it out, this will be the base of the pyramid
Turn the pyramid on its side and put the base in line with the bottom triangle
Then take some tape and tape them together
Then fold the base up and tape the rest of the sides
As shown above
Step 6: Making the Ramps
Now take the biggest triangle and draw the marble ramps using a pen and ruler, make the ramps 1.5cm or a bit bigger depending on the size of your marbles
Once you’ve finished drawing the ramps take some scissors and cut them out
You should have at least seven ramps
If you want a shallow marble ramp you might need to make some more ramps
Step 7: Attaching the Ramps
Take a ruler and draw an angled line on the pyramid
This is the mark of where the ramp will be
Now, using a hot glue gun stick the smallest ramp into place
Now take the second ramp and glue it onto the pyramid
Make sure the end of the second ramp is lower than the first ramp
This will let the marbles roll down
Step 8: Finishing Off
Carry on glueing your ramps onto the pyramid until you get to the bottom.
Congratulations you have now finished. You can enjoy rolling your marbles down the ramp.
you can personalise your marble run by painting or colouring it in.
