# Formula to calculate change in velocity for Hohmann Transfer Orbit
# Change in Veolcity = ((2 * Initial Velocity) * (sin((Inclination Change/2))))
# Use functions for left and right sides
import math
print ("Formula to calculate Hohmann Transfer Orbit")
print ("The formula for watts is: Change in Veolcity = ((2 * Initial Velocity) * (sin((Inclination Change/2))))")
# Define functions that will calculate the formula
# Calculate the left side of the formula
def leftsideofformula():
EnteredInitialVelocity = input ("Enter the initial velocity in meters per seconds: ")
# Convert to integer
InitialVelocity = int(EnteredInitialVelocity)
LeftSideOfFormula = (2 * InitialVelocity)
print("The left side of the formula is: ", LeftSideOfFormula)
return LeftSideOfFormula
# Calculate the bottom of the formula
def rightsideofformula():
EnteredInclinationChange = input ("Enter the inclination change in degrees: ")
InclinationChange = float(EnteredInclinationChange)
numberforsinecalculationradians = (InclinationChange/2)
# Convert to radians
# Use math.radians() function to convert degrees to radians
numberforsinecalculation = math.radians(numberforsinecalculationradians)
rightsideofformula = math.sin(numberforsinecalculation)
print("The right side of the formula is: ", rightsideofformula)
return rightsideofformula
# Use the left and right numbers to make final velocity in calculation
# Place result from function into variable to print
ChangeInVeolcity = leftsideofformula() * rightsideofformula()
print ("The change in velocity is:", ChangeInVeolcity, "meters per second.")
