Introduction: Python Greeting System
This tutorial will teach people how to create a home system that will greet people when they come near the sensor. This will happens by having a distance sensor detect when a person comes approximately 30 cm near the sensor. Once this happens the LCD will display hello to the visitor and a green light will turn on.
Step 1: What You'll Need
3 x 330 ohms resistor
2 x 100 ohms resistor
1 x 550 ohms resistor
1 x RGB LED
1 x Ultra Sonic Distance Sensor
1 x LCD Display
Step 2: Connect the Distance Sensor
1. Connect VCC to 5v power
2.Connect the GND to ground
3.Connect the TRIG to GPIO 21
4.Connect the ECHO to a 330 ohms resistor which is connected to a 500 ohms resistor that is connected to ground. The 500 ohms resistor should also be connected to GPIO 20
Step 3: Connect RGB LED
1. Connect the first leg to 100 ohms resistor which is connected to GPIO 26
2. Connect the second leg to a 100 ohms resistor which is connected to GPIO 19
3.Connect the longest leg to 5 V power
4.Connect the last leg to a 330 ohms resistor which is connected to GPIO 13
Step 4: Connect LCD
1. Connect the VCC to 5 V power
2. Connect the GND to ground
3. Connect the SND to the SND pin on the Pi
4. Connect the SCL to the SCL pin on the Pi
