print ("This program will calculate the net thrust of a rocket engine.")
import math
### Formula for calculating the net thrust of a rocket engine:
# NetThrustRocketEngine = ((ExhaustGasMassFlow / Time) * (ActualJetVelocityNozzleExit)) + ((FlowAreaNozzleExit)
# * (StaticPressureNozzleExit - AtmosphericPressure))
# Enter the ExhaustGasMassFlow, Time, ActualJetVelocityNozzleExit, FlowAreaNozzleExit,
# StaticPressureNozzleExit, AtmosphericPressure
def SolveForNetThrustRocketEngine():
print ("Solving for the net thrust of rocket engine.")
# Enter the Exhaust Gas Mass Flow
ExhaustGasMassFlow = float(input("Enter the Exhaust Gas Mass Flow: ") )
# Enter the Time
Time = float(input("Enter the Time: ") )
# Enter the Actual Jet Velocity Nozzle Exit
ActualJetVelocityNozzleExit = float(input("Enter the Actual Jet Velocity Nozzle Exit: ") )
# Enter the Flow Area Nozzle Exit
FlowAreaNozzleExit = float(input("Enter the Flow Area Nozzle Exit: ") )
# Enter the Static Pressure Nozzle Exit
StaticPressureNozzleExit = float(input("Enter the Static Pressure Nozzle Exit: ") )
# Enter the Atmospheric Pressure
AtmosphericPressure = float(input("Enter the Atmospheric Pressure: ") )
# Calculate the fraction
FractionCalculated = (ExhaustGasMassFlow/Time)
print("The fraction is: ", FractionCalculated)
# Calculate the difference in pressure
DifferenceInPressure = (StaticPressureNozzleExit - AtmosphericPressure)
print("The difference in pressure is: ", DifferenceInPressure)
# Calculate the left side of the equation
LeftSideOfEquation = (FractionCalculated * ActualJetVelocityNozzleExit)
print("The left side of the equation is: ", LeftSideOfEquation)
# Calculate the right side of the equation
RightSideOfEquation = ActualJetVelocityNozzleExit * DifferenceInPressure
print("The right side of the equation is: ", RightSideOfEquation)
# Add both sides together to get net thrust
NetThrustRocketEngine = LeftSideOfEquation + RightSideOfEquation
print("The net thrust of a rocket engine is: ", NetThrustRocketEngine, " Newtons.")
ContinueCalculations = "y"
# Check to see if the user wants to continue to calculate the net thrust of a rocket engine
while (ContinueCalculations=="y"):
ContinueCalculations = input("Would like to do another calculation for the net thrust of a rocket engine? (y/n): ")
print("==================================")
print ("Thank you to www.fxsolver.com for assistance with this formula.")
